cruiserdan said:Very nice!
pssst, paint the brackets....................![]()
I will, paints in the garage. Had a few projects going at once and this is as far as I got.
landtank said:... Had a few projects going at once and this is as far as I got.
landtank said:I shot the photos before PAINTING so they would be more visible.
landtank said:I think the hard line is better. I reused 2 of the original coolers mounting brackets and bent up some 3/8" tubing to mimick the coolers install. This way there is very little chance of rubbing a hole in the line and reduces the rubber hose used to just short lengths of connecting tubing. It also gets real crowded over on that side of the engine where all the PS hoses are routed. If you plan on just running 2 hoses over to the cooler then I'd get 2 grommets for the crossmember to protect them as they pass through. I founjd a site on the web that I was able to order 2 for my winch lines.
RavenTai said:steel line is actually less expensive than hose, or at least it was in 1/4", I used metal line for a diff/Tcase/trans breather round up,
stayalert said:My job looks like a total hack compared to Rick's but works perfectly fine for my purposes.
beno said:Raven--
You used metal line for your breathers?
Any pics of the routing on that? Sounds really soild.
Though, my concern with metal line would be on articulation--how will the metal line react to the extension of the axles on articulation?
Thanks!
-onur
beno said:And no problems so far?
I like Rick's set up and would be willing to do the metal tube, but my time and my resources are getting thin in this end...![]()
Thank!
-onur
