For ~50$ I got the B&M 70268 from
Summit racing. (
summitracing.com) cut out (with a dremel) my stock cooler, installed the B&M cooler, topped up the fluid and Bob's yer uncle.....
The black box below and to the right is a radar detector that came with the car when I bought it (used)
I primed and painted the bracketry that I used so it would be a few years before they looked like the bracket for the radar detector.
I tied in to the facory lines in a location that maintained the stock mounting of those lines (exceprt for the last mount (see mangled mount along frame rail?)
I have a front reciever hitch (the steel "beam" visible in the photos.) it didn't pose much additional challenge for routing of lines.
Where lines were or could be subject to wear I ran them hose in hose for chafing protection.
The hard mounting (as opposed to zip tie type mounting) that I did allows for about an inch of air space between the cooler and the a/C condenser. This is preferable for cooling efficiency
I'm hoping this will be an acceptable solution, it seems to work flawlessley. I'm bracing myself for ccriticism (constructive or otherwise bring it on.)
Rob M
1st photo shows patch that held fine for a week or so 'til I got roundtoit
