Before you start... I have searched. There are several similar questions, but none that I found quite describe what I am experiencing.
First, a bit of tech info:
- New battery/alt., both less than a year old
- Truck has been having intermittent starting issues
- Weather felt a bit more "static" than usual
On a short trip back from the local canyon today, I noticed the battery gauge was reading a bit lower than usual, only slightly above the halfway mark. I decide to drive around for a bit to see if the seemingly small issue would go away, but to no avail. Cruising RPM's varied between 2000 and 3200, stereo at average volume, lights on.
After a little while, I stopped at Best Buy to chat with a buddy of mine. As I attempted to start the truck again, nothing happened, only a click. This went on for 15-20 minutes, after which a kind old man helped me get jump-started, as the battery was running low. Surprisingly, it fired right up.
Now this is where a real problem decided to come in. As I shifted into Reverse, the battery needle drooped down 1/8-1/6" below the halfway mark, at which point both the stereo and radar detector cut out... Shifted back into Drive, the needle jumped back above the mark, then dropped slightly.
When I got home, the gauge was still reading low. I tested all of my lights set-by-set, and each set brought the needle down a significant amount, including the normal headlights.
I just had the alternator replaced no more than a year ago, and the battery was replaced earlier this year. The charging system seems like it works, but it seems like the battery just won't hold a charge anymore...
Any help appreciated!
Thanks,
Lane
Thanks,
Lane
