Power antenna
Pennsylvania
OK,,, I really hate to ask such questions, I've searched the web and searched the threads here. I just want to remove the factory power antenna and replace with a nice short rubber flexible antenna. It seems to me that the instal will go rather easy, but,,,,, Is there an easy way to get the original unit out? Naturally I'll have to move my window wash bottle as I've a dual battery set up, but beyond that, whats the story? Thanks in advance for all your great advise...
IIRC it will come out with a bit of patience, and it will help if you have small hands. I think aside from the hardware on top of the fender there is only one or two bolts holding in place, but you might have to cut the antenna cable as it is routed through the inner fender and firewall to behind the dash/ radio.
Yes, well I'd prolly cut it and use it to pull the new cable..
What antenna are you using as a replacement?
you may not be please with cheap rubber antennas. had one in the marshmallow when i got it and the reception wasn't good. went back to oem.
the coax is clipped in and that will be a pita to pull out. the antenna itself isn't bad.
I actually switched to a rubber antenna a few years ago and my radio reception is much better. I liked the look of the black flexible antenna, of course I don't have the part # but I know I picked it up at Pep Boys.
I want to do the same to. I have also searched and have not found a thread regarding easy replacement. If I can locate an instructional thread I would do either eom or rubber type.
Definitely do NOT pull the coax until you have a follow-up fish tape attached to it.
The coax is attached to the mast assembly, so you won't be able to reuse it with the new antenna. You do want to use the coax to pull the fish tape out through the fender so you can use it to pull the new antenna's coax back into the dash. You'll have a heck of a time trying to re-fish that hole if you don't. The outlet for this is at the very top back of the INSIDE of the fender, where it takes a 90 degree turn to go under the dash. The ultimate solution is to take the fender off, but you probably want to avoid that.
As for rubber ducky antennas, the reception and quality vary. You can find good ones, though I don't have any brand or model number. The Pep Boys one worked for someone else IIRC, so that's a potential candidate.
As for the factory power antenna, if you don't know, the mast can be replaced pretty easily and that usually fixes them. The drive unit doesn't tend to go bad much, it's just that the mast gets mangled.
I grafted one of those rubber antennas into what was left of my mast and it didn't have very good reception on AM. FM wasn't too bad, but I had FM reception with no antenna mast already.
I ended up buying all the parts to rebuild mine from CDan. I had to replace the white "cable" thing inside and the spool, as well as the mast itself. It is great now!
Dont you have to run the cheapo universal antennas directly to the head unit? If so, then y not just cut the antenna cable?
Yeah, sure, cut it off, but NOT before you've used it to pull out the fish tape to pull your new coax back into the cab.
If you just start cutting everything loose, then you'll have no easy way to get the new coax back out.
But if you're good at removing fenders, you can get easy access that way:rolleyes:
Truth is, even with a fish tape, getting your new coax back through is still not easy BTDT, presuming you want to skip the "remove fender" part.
Now, you can try adapting a cut-off factory cable to the new antenna. I'm sort of a radio guy and that would be a neat trick, but probably not reliable as a splice over the long term in an offroad vehicle. Much better to use a new unspliced cable.
My fatherinlaw gave me the rubber one, I'm either going to mount it on the Shortbus bumper, or try to get it in the original fender hole,, I'll try fishing the coax first. If that fails then up on the bumper it will go... It's my project for thanksgiving weekend ..
OK,, I confess, for some (to me) unimportant things I'm just flat out looking for the most economical way to get from point A to point B.. I have left the old power unit in place along with the original coax. (someday when it's important enough, and I have the time, a working power antenna would be cool) Someday, off in the future, I'll be getting a CB, so in the meantime, so I have good FM reception, I just mounted the FM antenna to the short bus. The rubber one was only 14", so I got a stiff mast of 18" , it should be tall enough. If it isn't, I'll hoist a 22" mast.. Here are some photos of what I did, tomorrow I'll just run the additional coax through the firewall on the drivers side, up under the dash, and plug it in. All my fasteners are stainless, everywhere, including our trailer, and most all are 7/16" for standardization purposes..
Nice installation. It will be interesting to see what you find when the antenna is in the "shadow" of the truck. In a big city, probably not so bad.
When my antenna was gone (broke off above nut and they cut the white cord! Augh!) I would get most local FM stations, but nothing for AM. Now I get them all good enough, but I have to run the antenna all the way up for the really distant ones. Mine is manual only.
Like you said, you can always run a longer whip.
If anyone here is looking for just a 6" rubber antenna mast that works like a bigger one I can attest from experience that this one works very well. Several of us on another board replaced the 18" masts on our VW's with 6" rubber masts and all understandably lost some signal, a lot actually. Then we found this "Hershmann" mast that noticeably improved reception. In fact I repeatedly switched between stock and new masts with the signal strength meter activated on my HU, and the signal was the same for each. And much better than the previous 6" antennas.
Scroll down to the $18.50 Hershmann model:
http://www.antennamastsrus.com/VW/VW Jetta 1999-2005.htm
If you mount the base for these masts too they have signal boosters built in to them. Might work out quite well.
I've replaced the amplified antenna base on a mk4 VW. It was a pain in the arse on a VW, can't imagine what a retrofit is gonna be like.
There's a nut on the underside that has to be tightened. Also, they use a tiny rf connector which is called a Fakra. I am pretty sure that this is a customized expletive just for these antenna systems. Fakra connectors are fragile and hard to find.
You could re-terminate with the oldschool automotive antenna connector. I forget what those are called.
SNIP
It's called a Motorola plug (the one with the long center contact housed in the wider metal plug) if you're talking the common one on most American cars in the recent past.
