Posting this on a couple threads.
The motor can be fully removed without removing the antenna cable to the radio by following the steps you'll find and bringing the motor through the hole into the engine bay. However at that point if you remove the screw just below where the antenna shafts meets the motor housing the shafts along with the attached cable can be separated and left in the engine bay. I was able to clean the brushes, not lose all the small parts and get everything back together on a bench which would of been about impossible
