Powdercoat a Turbo?
Cologne, MN
Can I powdercoat my Turbo setup. I really don't know what is inside that wouldn't withstand the 400 degree oven.
Has anybody ever did that? I am asking because I just don't know :o
I think the turbo will survive being powder coated... However the coating will burn off the turbo during operation....
The compressor end might be ok but the turbine end will just catch fire when the coating burns off....
Turbine ends can start to glow red hot......When pushed...
I think you need something more like this....
http://www.hpcoatings.co.nz/ExhaustHeatManagement/tabid/32279/Default.aspx
I know its a kiwi company but I am sure there are equivalents around the world.
Thanks for your information. I used high temp cast it on power decorating on my big block Chevy manifolds on my race truck, and they held up quite well. I'll check the heat rating on it
I got my turbo assembly ceramic coated. I did it mainly for corrosion resistance.
I painted the central housing of the turbo with four coats of high temp.
attachment.php
attachment.php
High temp ceramic coated exhaust housing, manifold and dump
Thanks both of you. I may look into ceramic coating. Both of your example as are very nice.
Next question-before i do this, how can I tell if the turbo needs replacing. Can it be tested?
If the wheels have cracks, chips or have touched the housings anywhere.
Leaking seals too
How has the ceramic coating held up? I think ive heard it has insulting qualities, so Im curious about coating the exhaust housing internally?
Do you just take them to a powder coaters? or is there a specific kind of shop to take them to?
How does ceramic coating hold up on stainless?
The ceramic has held up very nicely.
It absolutely has insulating properties. Both inside and outside. I think the ceramic helps keep the metal of the housing from absorbing some of the heat, and the coating on the outside helps keep it from radiating out so fast.
I notice a HUGE difference when I hold my hand an inch away from the ceramic coated turbo housing, and then move my hand over the bare steel exhaust pipe.
Many powder coasters can do ceramic coating, but not all. You need a dedicated oven to bake the stuff on--it needs 700+ degrees vs powder coat's 400-450.
Dan
Dan
Cool, it does sound appealing, thanks Dan, do you also know if it sticks to stainless fairly well?
