Powder Coated wheels
Reno, NV
Ok for those that have powder coated their factory alloys, did you have a problem with the powder coating being too thick on the hub surface? I was concerned with these wheels being hub centric.
Also does anyone know if the factory 93-97 alloys are cast or forged. Just curious.
I had a buddy that had a winch PC'd a couple of years ago and some of the mating surfaces were too thick and we had to grind it out to put the winch back together. Just want to make sure that won't be a problem on the wheels.
Jack
Mine were powdercoated LX rims and did not notice any mounting issues.
When tires are installed or removed, does the tire machine damage the powder coating around the wheel's edge?
Thanks Cory,
Good to know there's been new tire machine technology developed in the last 20 years. I know that PC would not stand a chance against the Coats tire machine I used to run 'back in the day'.
:cheers:
OE Wheels are forged. I had mine PC'd a couple of weeks ago and had no problems installing them back on the hub. I have in the past had the problem you mentioned with some other Toyota wheels. Apparently, the tolerances where too tight, and the PC made it difficult to reinstall. To remedy this, I took a hone, put it in my drill and took off the PC on the hub surface...worked great.
ALSO BEWARE! pc in the lug shoulders is thick, seems to gather there, and when torqued it WILL crack the pc under the lugs and cause them to come loose, on the hiway... in the rain... going down hill.... in a tight curve... after a few :beer:......with a semi hauling nitro behind you., most likely with bad brakes.:eek: dont ask me how I know this. And its not like you can drive it a day or two and re-torque, no no it will wait untill the wheel has been removed and put back on a few times and then driven about 34.3 more days when your totally confident. LOL moral to the story is, either have them tape off the lug shoulders or grind the pc out before driving it.
If you do get it done, would you post pics of the results?
The PO of my LC had 4 of the rims painted, now the spare is the only oringinal of the bunch. The paint is starting to flake off in areas, but not to bad yet.
I've seen on Mud, bead blasted wheels that look good, but what was done after for corrosion protection?
Looking forward to seeing this - what color did you opt for?
How much have people spent that have had them PC'd? I was quoted 80 bucks a wheel because they would have to be coated twice because the cast wheels would show pin holes after the first coat baked.
no need to coat them twice as out gassing takes care of the pin holes. I paid $60.00 a tire and had them done in a silver that they shoot regularly. The cost skyrockets if you get particular about having a specific color.
I would like to go 60% gloss black. Basic color.
Landtank, can you show us some pictures of your silver? Would love to see how they look, thanks
I haven't had it done yet, probably in a week or two. I am going with semi-gloss/satin black.
I called two places and they both quoted me $40.00 a rim, so $200.00 for all five. My stock wheels have the clear coat peeling off of them, so they look a little rough.
Jack
Forged - the expensive way.
DougM
