Possible Rear End Issue?
Guys, I'm not smart when it come to being any type of mechanic. Anyways, the last couple of days I have noticed some noise and a sort of "locking up" when I put my cruiser in reverse. The noise isn't noticeable inside the car, but my wife told me it sounded like I was dragging something when I was pulling up the driveway. I got in and rolled the windows down and it does sound like the brakes are wore out, even though I know they arent. Anyways, the issue of putting it in reverse seemed like it might have been due to not fully coming to a stop, and that was that. Today I got in, started it, put it in reverse, and as I backed about 5 feet, it sounded like it was grinding and "jumping" and trying to lock up... I am not anywhere I can check the gear dope at the moment, but what does this sound like to you more experienced guys? Any help is apprieciated. Thank you!
Sounds like your parking brake is probably dragging.
The "grinding, jumping and trying to lock up" doesn't sound like brakes to me. It sounds like there is something going on with the gears. I would pull the fill and drain plugs as soon as possible.
I can't figure it out. So should I drain the rear and refill? It sounds like the parking brake is on while driving, but I'm thinking the reverse gear jumping and hanging up has nothing to do with the brakes. I might be wrong, and that's why I'm asking. I thought about draining the rear end and refilling, but I want to hear what you guys would do first.
Oh you know what it could also be a caliper bolt that has backed out and a caliper is rubbing a wheel. Go out and look at all the calipers and make sure they are securely bolted on.
My thought was a shoe getting caught in the parking brake. Seems like something that might only happen in reverse
Guys beat me to it.
Pop loose your fill plug on your diff, check fluid level - if you can fit a finger in, see if you can get finger in fluid - supposed to be at level of plug anyway.
If you have fluid, more than likely not the culprit - i'd check brakes/other before coming back & doing a real drop/fill.
The calipers looks fine. The pads looked secure. I have it parked for the time being until I can get the tools to check the rear end. I'm just hoping this isn't major, especially right now.
