- Joined
- Dec 25, 2005
- Threads
- 195
- Messages
- 1,552
Recent purchase of a 1997 80 series. Was driving it and brake pedal became soft and went to floor before engaging brakes (and had to practically stand on the pedal for brakes to engage). Fluid level was at low mark so filled with brake fluid to full line on reservoir. Brakes worked fine for awhile, but after driving about an hour experienced same issue. Checked fluid reservoir and level was well passed the full line on reservoir.
This is my second 80 and had similar issue with last one that required the master cylinder be replaced. So, figured same issue here.
Dropped the 80 off at the dealership for repairs. They said the calipers were sticking on all 4 tires and new calipers are needed (when elevated on the lift 2 tires cannot be moved by hand and takes pretty good effort to rotate the other 2). I haven't noticed the vehicle particularly dragging when driving nor any rubbing or grinding sounds.
Before I jump off and have all new calipers (rotors and pads) installed, is there anything else I should be considering as the cause for the calipers seizing up? Just seems odd that they all would seize up at the same time.
