Ok, This may be a long shot, but here goes.....Shortly after purchasing my 1994 FZJ80 I made the rookie mistake of trying to remove what I thought was the MAF from the VAF body. I was not aware of the damage I caused and attempted to start the truck numerus times after doing this. Since making that critical mistake I have been chasing a rough idle. I've replaced the VAF and a boat load of other parts. Is it possible the damaged VAF somehow damaged the ECU?
I'm down to looking at a valve adjustment and injectors otherwise. A rebuilt ECU is cheaper than either of those. Below is a list of items I've replaced or work performed chasing this rough idle. OEM parts were used when available.
| SPARK PLUGS (Gap Checked) | |||||
| IGNITION COIL | |||||
| SPARK PLUG WIRES | |||||
| DISTRIBUTOR CAP & SEAL | |||||
| DISTRIBUTOR ROTOR | |||||
| FUEL PRESSURE REGULATOR / O-RING | |||||
| IDLE AIR CONTROL VALVE & O-RING | |||||
| VAF REPLACED WITH REBUILT | |||||
| INTAKE AIR HOSE | |||||
| PCV VALVE | |||||
| REPLACEMENT OF VACUUM HOSES | |||||
| OXYGEN SENSORS REPLACED (2) | |||||
| FUEL FILTER | |||||
| OIL FILLER CAP | |||||
| TROTTLE POSITION SENSOR | |||||
| TIMING CHECKED (4 DEGREES) | |||||
| SMOKE TESTED VACUUM LINES AT INTAKE | |||||
| EGR VALVE CLEANED-TESTED | |||||
| IDLE CONTROL VALVE PORT CLEANED | |||||
| EGR MANIFOLD PORT CLEANED ENGINE COMPRESSION TESTED |
