possible bent axle
high point nc
I purchased a 97 lx450 that has been hit in the left front by the previous owner. caster is off on the left front by 1.2° and the wheel base measurement shows the l/f is pushed back 1". I have a grinding/humm at highway speeds. PO replaced both front lower control arms after the accident. I drained the diff oil to take a look at the magnetic plug and found it full of metal fines. the oil was also very dark and silver. the PO had 4.88s and harrop elockers installed by a reputable cruiser shop so they were setup correctly. the diffs were done approximately 8 months ago. the lower control arm bracket is bent
my belief is that the axle is bent due to the metal fines on the plug and the caster being off on the left front. anyone had a bent front axle and had the same symptoms? looking for opinions
I bent my front axle housing due to an unscheduled jump. My camber was off by 3.7 degrees. Still very drivable but just barely visibly obvious. Drove it that way for over a week including 2 more days of hard wheeling. No metal on the magnet at all when I drained the diff. Hydrolicly straightened axle while still under truck. Well within factory specs now.
I would suspect damage to both axle brackets and frame bracket to be off that far. I would suspect damage to grunion bearings and or rotational twisting of knuckle/axle to move caster that far off from other knuckle. Aftermarket trunk in bearings COULD bring you back into caster spec, but that would not move your axle back to center.
I recommend a plumb bob and checking the frame. I did this on my previous FJ80 to check the frame and believe it or not it works. **Edit: and it's a quick and cheap check.
Here is a thread that may help:
bent frame or not?
Any pictures of this by any chance?
No. We were pretty busy inventing a way to accurately bend the axle back to straight. We do NOT have a frame and axle jig, so we worked with whatever we had handy. We had to get pretty creative, and it worked
