Position of Throttle Body Cabling
Dunnellon, Florida
Greetings all, recently I posted, "Failure to Start" about my 97 FZJ80. I was debating if I should continue with that or start new. Well new it is so here we go. I recently took off the Throttle Body to perform a cleaning. I replaced the TP Sensor and IAC Valve. Just for background the IAC Valve was faulty as described in "Failure to Start". However, I am still having uncontrolled max engine RPM on start up.
So I am thinking that I may not have reattached the Throttle Cable, Cruise Control Actuator Cable, and Accelerator Cable in their proper positions. Does anyone have images or diagrams as to which goes where. I think I have them right but better to double check.
I just now read Jbee's post "High Idle! Fzj80 idles at 3,000 RPM??" which is similar problem but with a different end result
