PO's speedometer needle
8000' Up in The Rocky Mountains, CO
I finally got around to fishing out the broken speed indicator needle. Is there any repair for this?
Anyone know where to get one?
seriously, you may want to consider super-gluing the needle to the round part by overlapping it on the face of the round part. Get it? The needle will be shorter now or maybe make your own that is longer.
Attaching the needle at the actual point it broke off prolly ain't gonna be to successful.
Don't know it's worth the trouble
But with a Dremel tool you might be able to make a new piece of metal and re-attach like factory then just paint the needle part with Testors.
I had to do something similar on my temp gauge. I used jewelers files as I can't find a Dremel Tool here.
What have I done to my 40 this week? Destroyed the ODO, I think. My fuel gauge quit working last week (Jan, 76 make). I managed to track it to a short in the cluster. When I tapped the gauge, the needle would move. Cluster out, contacts shined. However during removal, I cracked the plastic mount where the odo cable plugs in. I gave the crack a coating of glue and let it set up. After reinstall, the fuel gauge AND temp came back to life. However, my odo needle started turning laps around the odometer, full 360 degrees and bent my odo needle over. I'm taking the cluster apart again to try and fix the needle. NOW, for the big question for you - What did I miss? It sure seemed like the cable was fully seated on the cluster. Clip was engaged.
Also, I'm hoping that attaching my question to an old post is the best way to consolidate information and show that I have done my homework on this.
Thanks in advance!
Thanks in advance!
I am seeing play in the needle shaft. The shaft is moving front to back, sometimes failing to catch on the stop at the "0 mph" position. Also, yes, the needle spun clockwise...
Well, I reassembled and reinstalled, careful to put the speedo needle on the 0 mph stop. Same results - a free spinning needle, bent up again. I unplugged the damn thing. I'll just have to watch my speed :hillbilly::cool: At least i have a fuel gauge again! For the moment...
Check your cable inside the sheath. If it's binding then suddenly freed up, it'll cause the needle to do what yours did. Ask me how I know...
