Ratpuke
- Joined
- Jul 2, 2002
- Threads
- 262
- Messages
- 3,328
Awhile ago I posted up a thread about the coughing and surging in power that my BJ73's 3B exhibits, usually only when the engine is cold. The original thread can be found here: https://forum.ih8mud.com/diesel-tech-24-volts-systems/86336-surging-smoking.html
Up until recently these problems seemed to only occur in the late fall and early Spring - when temperatures are low enough not to be warm but not cold enough using the Webasto to pre-heat the coolant. In the winter I generally used the Webasto to heat up the engine so the problems weren't an issue in the winter.
To recap, the truck is a 1985 BJ73. It has a 3B with a rotory injection pump. When I got it, I could usually squeeze 800km out of a tank of fuel. Now it's empty at around 600km.
Over the past few months it has started to really run quite poorly. On a typical morning I start the engine up after glowing the plugs. The engine idles normally for a minute or so. I then back out the driveway and head off to work. I don't get very far - usually only a couple of doors down when the engine really starts to knock and lurch about (as though it was being driven by someone just learning how to drive a standard). The engine would normally stall out and then I have to restart it. It fires up again but this time I have to step on the throttle in order to keep it idling. It'll blow black smoke at this point. I keep the pedal down a bit longer and dial up the hand throttle - it keeps it running and idling ok until I make it to work. On the way home, after the truck has sat all day, it does it a bit, but not nearly as bad.
So, now that it's starting to become more of an issue, I decided to pop the hood and take a look to see if I could spot any air in the line (which was brought up in my past thread). Bruce and I had swapped out one of the fuel lines a year ago (ok, maybe 2 and I forgot to put the right hose back in so that's why it's still in there).
Upon inspecting the engine it was soon noticed (by RockDoc) that the rotary pump was covered in diesel. There wasn't a need to clean it up because it was apparent that diesel was coming out of the top part of the pump (as labeled in this picture
