For Sale Portland, OR: 1994 FZJ80 built, lifted, ARB locked
Mallorca, ES / SD, CA
Year
1994
  1. 80 Series
Mileage
295000
Feeler post for interest in a trade of your overland LX470 or 100 for my built, triple locked 80 on 35s with a proper suspension setup. Cross posting from the 100 series classifieds. Straight sale only at this time.
This is a '94 truck in Dark Emerald Pearl (6M1) with brown fabric interior.
The basics:
- ARB locked front and rear wired into Toyota factory locker switch, CDL switch in dash. ARB compressor
- Regeared to 4.88 for 35s
- OME heavy springs (2850J, 2863J), OME shocks (60070L, 60071L). OME steering stabilizer. Caster correction via Tough Dog plates. Poly bushings all around. Adjustable control arms. Adjustable panhards. Suspension geometry fully restored to factory spec and professionally aligned.
- Dual batteries, Blue Sea ACR, terminal blocks for accessories
- DEPO glass lens headlights with Osram bulbs. LED signals and brake lights with correct flasher relay
- Recently replaced all window rubber channel runs, belt molding, and moisture barrier inside doors
- NWTI modular bumpers with tire carrier, ladder, and jerry rack, Trail Tailor sliders, and modular KISS drawers in cargo area
I've owned the truck for 1.5 years, got it from another Mud member, mitchbenson who did an extremely thorough job of baselining and building this truck for wheeling in Utah. Here's his original post from 2019 detailing the build:
For Sale - SOLD. SLC: 1994 ARB Locked, Armored, Baselined FZJ80
I could write a dissertation about the build journey for this rig over the last 2 years. It's been fun, but life circumstances change (for the better) and it's time to focus my attention on other projects. 1994 FZJ80 Clear, no accident Gallery linked here. Carfax attached. Fully baselined -...
forum.ih8mud.com
forum.ih8mud.com
glenwoodtribe.smugmug.com
1994 FZJ80 - glenwoodtribe
I got it at ~285k and it's at ~295 right now. Since acquiring it I've done a few things:
- swapped the Toyo MTs for Falken AT3W in 315 (35") for the snow rating
- installed a full Trail Tailor vinyl floor with heavy duty Noico in the cabin floor and front doors
- new Denso plug wires and either NGK or Denso plugs, can't recall
- Hella Supertone horns behind the front grille
- new front sway bar hardware from Kurt
- replaced all 4 window rubber runners and black door belt molding with OE Toyota
- replaced the front moisture barriers with OE, repaired the rears
- installed new JBL speakers in the front OE location and a Sony CarPlay head unit, used the Crutchfield kit so it's easily reversible
- installed a backup camera that ties into the stereo
- installed Depo H1/H4 headlights with glass lenses and Osram off road bulbs
- converted the corner lights and front turn signals to clear lenses but retained the original factory trim from the 94 so it all matches. Did the signal swap mod so the corner lights are turns for better visibility, which is fully reversible if you don't like it
- converted all turn signals and taillights to LED including the correct flasher relay from SuperbrightLEDs
- resealed the windshield gasket with 3M butyl per the FSM procedure
I have three bins of spares and OE parts too, including the OE headlights, marker lights, and the third row seats with pretty good fabric, as well as a Pioneer DVD/android auto HU that I removed.
This is a solid trail, camping, and moderate crawling rig. The clear coat is in bad shape on most of the truck, there's a rust spot developing on the hatch and on the rear passenger quarter where it has some trail damage, but otherwise the body and glass are in good shape. It was mostly a PNW truck so little if any road salt exposure. The sunroof seal and drains are problematic like most 80s, so it can leak in an automatic car wash or a very heavy rain. It has a couple oil weeps and will consume 1/2 L of oil in an oil change interval. I use full synthetic in it with a MoS2 wear inhibitor and Toyota oil filter. Currently running the washable Toyota air filter but can include a K&N if you prefer.
It passes Oregon DEQ with no problems and has all the factory emissions hardware, other than aftermarket cats. There are a few interior trim pieces broken or missing like the steering column clamshell trim, a rear speaker grille, and rear door lever garnish.
I really love this truck, and it's way overkill for what I ask it to do, which mostly is primitive camping here in Oregon and occasionally being an emergency escape vehicle for snow and weather. It is not a garage queen type of truck to look pretty for Instagram likes but never get dirty. Rock solid driving and engine temps from climbing passes near Mt Hood down to driving the salt flats in Alvord Desert in August. AC blows cold and the rear heat works.
Included equipment:
- NWTI front and rear bumpers with single swing tire carrier, ladder, and locking dual jerry can rack. All bumpers and armor are raw steel with forced patina using Ospho
- Trail Tailor sliders
- Modified KISS drawer system with two drawers, left top panel removed for fridge/cooler use, matching panel included
- Aluminum tailgate storage panels
- 3 Bins of spare parts and original parts
- Clean Oregon title in my name
- Clean Carfax report
- Roof racks, RTT, and jerries shown in some of the photos are NOT included— I didn't get them from the PO
I'm looking for a later model, preferably 03+ truck. Agnostic on LX vs LC, would prefer thoughtful mods (eg bumpers, lift, sliders) and good maintenance records over stock and low mileage. Strong bonus points for a Cypress or Galactic Grey rig with projector headlights and a mild overland build. Swap your IFS truck for a solid axle beast!
I'd strongly prefer a trade, but I'll consider an offer I guess. Happy to let you check it out as well.
Updating this post as For Sale; my heart is still open to trades for a 03+ LX but my brain knows I need to upgrade our daily driver and this 80 rarely gets driven these days. It kind of breaks my heart to see it sitting and it's time to rehome it where it will be used.
I'll post this outside Mud for probably $13k, so 12k for Mud.
Hi! I'm very interested in a flat purchase if you have not had any luck with other inquiries. I am located in WA as well. Thank you!
More PMs replied to. I'll be traveling for a few weeks and won't be able to show the truck until early March.
Ive got a higher mileage 100 with tons of maintenance done in the last couple years of my ownership. Model year 2000 with ~380k on it. Send me a PM if youre interested, cash on my end
heading out tomorrow for a trip, no deposits received to date so the truck is still available. I won't be able to show the truck until March but will gladly discuss details and answer any questions.
