Plug on transmission cover?
There is some seepage of dark oil around the indicated "plug". Is this just a cover for the transmission? The plug seems to be plastic and is not substantial in any way. Can anyone tell me what this is for? Thanks in advance!
@AUMike99
You should post more about your truck (year, mods, etc.)
Your picture appears to show the clutch inspection cover. Leaks emanating from that spot could be related to the transmission input shaft seal, or engine oil from the rear main seal, or somewhere on the rear of the engine.
You should be able to differentiate transmission oil from engine oil by the smell.
Removing the cover would allow you to see drip marks as well.
@AUMike99
It is a 1981 FJ40... with no mods. Your reply actually helped me quite a bit by simply identifying the cover. I will remove and inspect.
Thanks.
Finally got around to removing the flywheel cover with extra time on my hands. Upon removal, I discovered the attached piece sitting in the bottom of the cover. Anyone recognize what this might be? It's tapered on both ends and is about the size of a 9mm bullet.
Dowel pin for the flywheel, as has been said.
Perhaps fell out during installation and not noticed...
