I'm really at a loss to what I'm missing here.
Did the timing procedure, and all looked to be well. Arrows on the belts were in the correct location, timing marks were lined up on both cams and the timing belt gear to oil pump casting:
But then I added the timing cover (brand new, so should be unwarped, with all hardware, so should be properly located), and it's not ever close. Reading with the cams as above:
Pulled it back off again, and the gear to oil pump mark still seems to be bang on.
What am I doing wrong?
