Please Help Me "Design" My 80
Ok, I'll try to give as much info as possible for my plans, and maybe more importantly to seek advice of what I may run into.
I took over DDing this rig from the :princess: in Jan. Very clean, no scratches, etc.
I will probably never wheel it hard, at least while it is a DD'r over the next few years.
I took out a deer last night. Called Christo today....and so the slippery slope begins....
I need an ARB. Like the Aussies do. Deer are thick in this town I just moved to. I see a dozen or so a night, in my heavily populated neighborhood, inside the city limits.
So, I understand the lift is not that far off now. I'm running 285 Revos and love them. Really no plans to go bigger at this point.
So I'm thinking 2.5", maybe the spacers up front.
I will be starting to take my small children camping within the next year. No real plans for heavy loads like drawers and full recovery gear....more like coolers and tents for a night or two.
I do plan on a rear bumper w/ tire carrier, not of need necessarily, but just to complete the package. Step sliders because it still is a family rig.
Light wheeling, but enough protection to keep me from doing damage because I'm not on 6" springs and 35/7s...
I don't want to get into the driveline vibe issues, and frankly don't feel like being a test pilot for new products. I just don't have the :banana::banana:s to get those sort of problems sorted out...nor the time.
So there you have it....maybe this is a dumb idea, I dunno. My head hurst from reading everything and trying to decipher the good relevant stuff from the not, and trying to remember everyone's who is posting mods so I keep in mind the varying perspectives.
I assume Christo will be taking my order shortly...ARB Deluxe....I probably won't be putting a winch into it but want the room to grow.
ARB upfront, prob a rear tire carrier in the future, and some sliders.
Any suggestions?
Slee can hook you up with the ARB, step sliders, OME lift, and bumper/rear tire carrier. His products are very good.
Hook up with the Upstate Cruisers...all it well :)
uhh...yeahh
With my luck I'd get talked into following the Avacado up/down "an easy trail":doh:
I'd be better off riding shotgun and doing my best to mimic NorcalDoug's recipes, E Coast style, off my virgin 80's tailgate in base camp:D
:beer:
Maybe I should dive back into the search...and write things down. Just seems like a nightmarish trip of driveline issues and CC fixes from a myriad of parts.
Some have issues, some don't....maybe all of that is from higher lifts and bigger tires than I'm planning on...
I'd very much like to dive in and do it once...well not really, budget is an issue, I may have to spread it out over a few years....but starting out there is no way in hell I'm spending any money for the bumper fix that does not include the letters ARB;)
FWIW:
Factory lockers....I installed a CDL switch last weekend while taking a rest from the O2 nightmare.
No pin 7 mod, yet.
33s
My fixes to date are the o2s (WOW that sucked)
Starter contacts
2 power antennas:doh:
Mobile 1 in engine and tranny
Pesky door latch fix
Limited tools, but growing (about $150 worth just last weekend;))
Limited skills, but trying.
CC---- long time no see
I think if you stay in the mild 2.5'' lift range you will not run into any vibe issues. most of that starts w/ 3.5 and greater ie ome J springs and beyond. a real popular option is the 850/863 springs for a level stance. then you got the arb, some step sliders for the fam (and the rockers) and a rear bumper w/ swingout and you got a well set up truck for family camping and beyond. the ome kit should come w/ cc bushings and again if you are staying at this height the bushings will work fine for you. good luck on the build and keep us posted.
id say get your bumper up front and some sliders. then work on your lift, and lastly your rear bumper.
I appreciate it man. Just what I needed. Cutting through everything I somehow managed to confuse myself about after reading many threads that have no relevance to my situation at the time.
I did start calculating bumper/winch weight this morning, and quit when the cold medicine kicked in.
I'll check out the 850/863 combo, and do some reading...No stinkbug? Spacers required? No need to reply, NOw I've got the narrower kind of info I know search can help me out on.
I was just going to buy the bumper, and then the lift, but I know that is sort of bassackwards...
Rethinking that now....
:beer::beer:
Edit: Pretty tempting to just order the ARB and either the 2.5 heavy or medium kit and call it a day!
Edit of the Edit: I have ruled out the mediums based on Romer's experience with it.
The heavy kit is going to push your caster limits with just the bumper. It depends how sensitive you are about that kind of stuff.
You might consider the straight OME "stock height" kit, which will probably give you about an inch of lift over your 10+ year old stock springs. Add 20mm of spacers to that, and do the OME CC bushings. That will keep you at a very safe lift height (about 1.5" over what new factory springs would give you) from a vibes/caster perspective and look very good with 33's.
If you go OME medium with the ARB, the front is going to be pretty low compared to the rear, which is why you are getting the suggestion to do OME heavy front/medium rear. Just keep in mind that this is a straight 3" lift that has no guarantee of no issues.
I think the 33's will look better with a bit less lift - the 80 tends to swallow tires and 3" of lift looks good on 35's. Keep it lower and I think you'll be happier.
It sounds like you should get the OME HD 2.5" lift. I think It will work good for you.
we drove our truck for well over a year with only a ARB in the front no sliders or rear bumper and the ride was fine I think.
Don't packer the front I did it and didn't like it. Castor/feel is better if you don't mess with it at all.
This is a good starter kit.
Good info on both of the above.
I'll look at pics of 33s with the 2.5(3") and see what it looks like. Yes, looks are important to a mall cruiser (our mall has really high curbs;):D)
I don't like the idea of spacers, but have no basis in fact to back that up.
I took the medium kit out the equation, but that brings up an interesting point...
Anyone ever hear of anyone else doing the mediums up front and the OME "stockers" in the rear?
(off to search)
I have the OME medium lift (851/860) with 33's and no additional weight. My truck measures 22" from the centre of the front hub to the bottom of the flare, and 23" in the rear. 20" is the stock measurement on the FZJ's (last I heard anyway). 2" and 3" averages out to 2.5", hence that being the lift height. Here is a link to some pics (I'll buy a star soon, I swear:o)
Thanks everyone.
I've reread or at least scanned about 150 threads with OME in the title.
I've basically determined that I'm guilty of what everyone is trying to tell me what not to do (buy too little insteading of buying right the first time), considering I will eventually have sliders and a rear bumper. I think I overestimated the drawer system's weight and gear that I doubt I'll ever carry, but even that is not of the question ( I do like to be prepared). I hate stinkbug, but an inch I can deal with.
I do not want bigger than my Revo 33s, but I also can't stand not enough rubber in the well.
I appreciate all the input this evening!
I guess it should be noted that I do have garage clearance issues, and after reading a few of Concrete's posts, I'm considering the medium and then loading it down some. Still bucking conventional wisdon I know, but after typing the above and reading Christo's description of "harsh ride if no wieght is added" on the heavies, I guess I'm back to square one for the moment:doh:
It would be a long while (year or two) before rear bumper, sliders, and a winch would be installed into the new ARB Slee is about to sell me
I have the medium kit no ARB bumper and use my rig exactly as you describe..
I loaded the rear end up last weekend with camping gear, tools and recovery gear, and it still sat level. I think you would be very happy with the mediums, and if the front comes down a bit, add a spacer--they aren't bad.
Where are you in the Carolinas? If you're near the Triad or Triangle, check the NC board here and come check out some 80's.
FWIW I have a 95 w/ 285 Nittos and did the stock height OME + Bilstein combo. I have no extra weight yet, just plan on a bumper and some sliders next year. Even this combo is somewhat harsh - not sure if it's the springs, shocks, or tire sidewalls. (I can't imagine heavies on an unloaded truck.) The height is perfect w/ the tires, it looks ideally proportioned.
I'm in the Upstate, I think it is called BFE;)
Got a link to some pics?
What air pressure are you running? My revos felt like rocks on the ride home after installation....the truck shop guys put 55lbs in!:eek:
Much better ride at 32, FWIW.
I could probably in all reality be just fine with OME "stock"...and a spacer....no, I would be fine.
I plan on keeping this one forever, so I can't help but think 2.5 might be better down the road when I use it more for fun than for commuting.. I do like the way the Revos fill the wells currently, though.
Here is what OME medium looks like on 33" Interco trxus MT's. There is plenty of room to run 35's, which is what got me started to the suspension I have today. Second pic is OME medium on 35's (which will rub due to OME's shock travel design unless you drop your bumpstops). I think it is pretty obvious even on the OME medium lift how much better 35's fill the wheel well and give a desired aggressive look. 33's will give more of this proportional look on a lesser lift if that matters to you.
Thanks for the pics. I've been reading ROTWs all morning...starting to lean more to the medium and loading it...Just don't need or want to get into the driveline-problem zone.
The first pic is exactly how I'd like mine to sit after it is loaded.
(I love the look of the 35s too! Just that that is part of the slippery slope I'm not ready to go down yet;))
med OME, then get sliders!!!! Like Dan said, come to one of the upstate events and you can probably check out a variety of combinations in person.
