Pitman arm
dont know if they are even available now but back in the 70s i was doing power steering for other 40 owners and used a pitman arm from a 70 olds bolted up to both styles and was short so steering wasnt so quick
You custom make a drag link
Chevy one End Toyota the other
Or you get somebody to ream
the correct taper into the Saginaw arm you have
The pitman arm that I have was a sandwich of the manual Saginaw box arm and the original Toyota arm. I`ve been running it for about 16 years. the guy that welded the two together was a certified welder. It`s been ok all these years. I took the cruiser to a front end shop to have the tow in done and he wouldn`t do it because of the welded pitman arm. So I thought I would try to find one. The Saginaw box is from a 1960s era chevy with manual steering.
Push a couple pins into the centre of the tire half way up, measure the distance between the pins at the rear, roll forward so the pins are 1/2 way up at the front, measure, and adjust toe till the front is about 1/8” shorter at least the front. Repeat until correct.
Or buy a TRE from a ‘90s GM truck that has metric threads and a Saginaw taper. Find a pitman arm off a stock Heep that’s the size.
I have a mid 60s manual chevy steering box. I don't have the original pitman arm. I`ll try the olds pitman arm, thanks.
I think I`ll try the tow in adjustment with the pins, and run my old pitman arm for a while longer and start checking the wrecking yards. Thanks.
Like bikersmurf suggests do the toe in yourself. The pitman arm you have probably is fine then.
I had a welded high steer double arm myself for years never had an issue. But I did finally upgrade my steering components. I also used to heat and bend my steering arms which they say is a no no .
While your messing with Your steering why not swap the manual box for a power steering box. You will love power steering.
Thanks much for the info. I think I`ll run my old one for a while until I check the wrecking yards.
I`ve been thinking about going power. A friend of mine changed his fj40 to a power box. It looks good and feels good.
Looking forward to P/S. I’ve been collecting the parts for a while. Was lining up to do it when the engine spun a rod bearing. P/S got pushed off it was roadworthy again.
I’ve been aligning mine for 25 years now. Three sets of tires have all worn evenly... despite never having bought a new set of TREs.
