Pintle Repair?
Kansas City
All, I have been searching and can not find an answer to this question. Admittedly, I do not know enough about bodywork to figure it out on my own, so any guidance here is much appreciated.
I recently purchased and received a nice spare tire mounting arm from Mark at Detours of Maine. It is designed to bolt up to the four holes of the pintle. However, when I went to check out what would be needed for the installation, I noticed something unusual with the four holes in my cross member that I was so anxious to take advantage of. From the outside, the "inner" threaded part of the two top holes seemed to go up at an angle from the opening instead of straight back, and seemed to be "disconnected" from the outer part of the member. Upon further investigation from the inside looking through the access area, I found that there seems to be a plate that is very deteriorated and flaking away from the main tubing of the cross member. This was surprising to me because my cruiser is relatively "rust free."
Is this a piece that can be replaced? What are my options here for being able to use my new custom mount? I tried to take the best photos that I could... I know that some will say, "Time for a new swingout." However, I really like the look of the OEM setup at the rear and honestly would rather not go that route. Thanks for the help!
The lower part is pretty well rusted through and is of questionable integrity. It'd be nice to see a picture of this mount to see how it transfers the load of the tire to the crossmember but...
Assuming that the mount has a plate of some sort that spans to the upper and lower edges of the cross member you could just drill through the upper nuts and through the back side too. Use large, thick, fender washers and through bolts on those two. For the lower holes you can also drill through the nuts but you'll have to find something that spans over the access cut out. Fender washers may work or get yourself a piece of steel flat bar that covers that opening and drill two matching holes, then through bolt it too. You could also find a large enough flat bar that you could drill 4 matching holes in and use it on the back side for all 4 bolts. Just make sure it spans over the cut out as far as you can reasonably fit.
No matter how you go you'll want to remove as much of that flaking rust as you can and seal up that area with some rust preventative paint. I've had good luck with POR15 and Chassis Saver brands.
I would not use that. If you're dedicated to using your bolt on swingout, I'd say the best option would be to cut out your whole rear crossmember and weld in a good one from the scrapper. It will be a lot of work, so even though you don't want to hear it, maybe it's time to look at a different swingout or put the tire elsewhere.
Thanks for the replies. I stole a pic (below) from Mark's FB page to show how the mount would look, and HERE is a link to another write-up that shows photos of how it swings down as opposed to out. Mark also makes a version that utilizes the trailer hitch; I'm wondering if I should see if he can convert mine.
That mount plate is a little small and with the rust on your cross member around those holes it would concern me. If cutting out and replacing the member is not an option then I would want to put another plate on the outside too that spanned over to some more solid metal.
If you don't off road the trailer hitch option would work.
