Piggy stimulus plan.
bobm
WTF, dat mean. 🐖👈
Land of the Free/Home of the Brave
SPRING IS AROUND THE CORNER. The PIGS are all in there blankets being worked on and getting ready for warm weather. Its time to stimulate your PIG. This is a one time 4 week only offer for your PIG. This is what your PIG gets. At 1/3 off the total cost not includeing shipping. P.M. if interested and for your savings.
1.) 2 Rocker panels.
2.) 2 Front body mounts.
3.) 2 front floor pans.
4.) 4 floor supports.
5.) 2 rear floor pans.
6.) 2 "C" pillar body mounts.
So basically you can replace everything from your PIGS kickpanel to rear bench seat and from Rocker to Rocker with all new material for a substantial savings. 1/3 off. See my previous post for all items. All made in the Great U.S.A.:)
Cut lines
Osage, as far as crossbracing the more the merrier. The cross bracing should also be tied into the Floor, Tranny hump or above floor supports. These are the cut lines. All the material from old rocker must be removed from under the pillars. If you look at the first pic this feature must be retained as it curves in-ward towards the engine compartment to keep the lower door corner from binding on the rocker. Hope this Helps.
Thanks Bob.
