Pig (FJ55) Roof Panel w/ Surface Rust - How To Proceed?
Dang! Min order is 4 gallons @ $129! Anyone want to split an order?
Lowes, Home Depot, etc should have what you need in much smaller quantities.
W/ Rustoleum - I found that Canvas White (I believe) almost matches the factory off-white exactly. I painted my Pig with it and it came out pretty nice for a trail rig.
rust bullets and rattle can
repaired my surface rust fj 55s floor pans with Rust bullets then rattle canned with local OReilleys color match..Linen white.........:banana:
stripped floor pans with wire brush on a 4 1/2 inch side grinder; changed wire brush then flapper wheeled......... then etched with spray phosphoric acid from rust bullet........flapper wheeled again a few rough spots then etched again...washed off with hot water to neutralize the acid...then rust bullet silver X 2 coats..... used a 2 inch brush; let cure X 72 hours then rattle canned with the OReilleys rattle can color match.........looked very nice then covered with "Lowe's" brand of Dynamat; Pablo, always use a good quality mask and eye protection HTH;
Lou
TJ,
At my shop, I also have everything you'd need. But here is what I would do.
1. remove the rack
2. get a good step ladder and us a DA sander (120 grit) to knock down the surface.
3. Go over it with 220 grit.
4. Use an epoxy primer (I use U-TEC on all my stuff, its good quality and is actually sandable vs. some of that other crap you see out there like OMNI /cringe)
5. After two coats of epoxy primer, hit it with a light coat and a heavy coat of high build and then block it down.
6. Hit it with a sealer (usually the highbuilds today can be reduced down enough, according to the spec sheets).
7. Base coat.
8. Clear coat.
9. Buff.
10. Enjoy.
That would be a fairly easy job, minus having sore arms working on the roof.
See ya,
dallas
