PIC ReQuest A/C Schrader Valve
Los Angeles, CA
Website
www.phipsi.net
Like the title says...a pic of the valve that i can release the pressure from the system...and what tool/s I need to do it would be awesome...I don't have my FSM around and have yet to mess with the AC system.
I'm removing it and don't want to just cut it up (just yet).
Thanks in advance. I really appreciated it
it sounds like to me that you want to undo the shrader valve to release all you gas. correct?
would it not be just as easy to undo one of the hoses say at the reciever dryer.
if you want to undo the shrader valve sometimes you can use the valve stem cap on your tyres.
Here's a pic of the top of the compressor. I removed the low-side cap, so you can see the schrader, more or less. Ideally, you would take it to a shop to have the refrigerant recovered, rather than venting it to the atmosphere. If you choose to release it yourself, use extreme caution, as you can inflict some serious damage if you come in contact with the refrigerant.
I am planning on removing the whole system and have the truck pulled apart so it is not feasible to take the truck to a shop to have it done by them....I'd like to even remove the A/C compressor and relieve some engine strain. Just have to get a custom pulley cable made to account for the change in pulley length from removing the A/C compressor.
THANK YOU 72FJ55 for the pic. I really appreciate it.
There is no real engine strain with the compressor not engaged. Removing the belt will fix this as well. No need for another pulley unless you have something that is not stock.
Note taken...so I will just pull the belt and the AC comp. all together.
most of the lines, res, and condenser removed. Will remove the Compressor tomorrow.
