it's mounted on the passenger side but designed for the driverare you able to view it if is on pass side?
got it, thanks!it's mounted on the passenger side but designed for the driver
Angled Dash Mount for Toyota Land Cruiser | ProClip USA
www.proclipusa.com
Another + for proclip. I’ve used mine for about 3 years with no issues.+1 for pro clip. I put a belkin MagSafe charger on mine.
The problem with these mounts are:got it, thanks!
Double sided tape. In the heat or cold, for me, it always fail at the wrong time. Causing my expensive phone to fall at the wrong time while driving and damaging either dash below or phone.So I use this one Steelie® Squeeze® Dash Kit - https://niteize.com/steelie-squeeze-dash-kit and have it stuck right on top of my vent so my phone doesn't impede air flow. Here in Texas we need all the AC vent we can get in the summer! They must have updated the squeeze-clamp as I've had mine for a couple years. Only thing I've had to do to it was replace the double-sided tape that held it on. Hope this helps!
Does it block hand brake?I used the quadlock. Was very sturdy and by far the best one I’ve used. The MagSafe charging was a bonus.
To each his own. I never had a catastrophic failure with double sided tape. It eventually (after a year) started peeling on one side so I replaced it. If my phone ever felt hot-hot I just slid it down a bit to catch the top of the A/C. Never once overheated. That’s my experience but yours may differ.Double sided tape. In the heat or cold, for me, it always fail at the wrong time. Causing my expensive phone to fall at the wrong time while driving and damaging either dash below or phone.
Also mounting it that high means that your phone is directly exposed to sun. Drive that for an hour or two in either early morning or late afternoon while using navigation/music and your phone will over heat. Yeah you get more airflow but your navigation just shutdown OR your screen dims so much that it is useless.
This is why AC vent mount is the best. You can navigate for hours and hours without a hiccup. And I have zero issue with AC even in 110+ temp bc LC air conditioner is strong as heck.
Only when the phone is on but I hardly ever use the e brakeDoes it block hand brake?
is there a website to order from?Got my phone mount from a company called Thabt based in GCC, it’s the most OEM solution I found for the 200/LX series and a bunch of other car models. They sell a trim that you attached to the passenger footwell side and from there screw in any mount you like , I choose a ball mount receiver and installed my trusty MagSafe phone mount, its so strong that it holds my pixel 8 which obviously not MagSafe compatible
Thabt.qa
Thabt.kw
Thabt.uae
Thabt.ksa
View attachment 3472650View attachment 3472652View attachment 3472653View attachment 3472654
instagram dm, checkout the instagram story highlights for specific models.is there a website to order from?
ah ok thanksinstagram dm, checkout the instagram story highlights for specific models.
I use something similar but with this disc mount, works well Even though the dash isn't flatI have this mount on the left side of the window and routed the cable under the steering wheel. Holds super sturd on amd offroad and never had a problem with it holding my 14 Pro Max.
And the price is also pretty okish.
Mpow CA032E Car Phone Holder - https://www.xmpow.com/de-de/collections/car-phone-mount/products/mpow-ca032e-car-phone-mount-with-extendable-arm
