PHH today
Atlanta
Normally I am a "if it's not broke don't fix it kind of person". After all I read about the PHH and considering I had 225K on mine I decided I better go for it. Took 2hrs and I used NAPA green silicon hose. It was a long day I also installed KYB shocks, new rotors, pads and wheels bearings. tomorrow the rest of the hoses and belts.
:beer::beer:
Those clamps will be a lot easier to get to in a few years, eh? The factory clamps are in about the most difficult to access position they could devise. Kind of a rite of passage for 80 owners, so well done.
DougM
255K? Nice. And clean up under there too! This is NOT a sign of a 'don't fix it 'til it's broke' person. Are you lyin' here?
Bet you're glad to have that one under your belt? Good work.
Dan.
I'm the more, wait until it leaks, then leaks a bit more, then close your eyes and pretend the
overflow tank is not empty kinda guy, on PITA jobs like this.
Nice job.
g
did mine today too, its 10 pm here now, i started at 8 am, got hoses belts and flushed rad about 5 or 6 times along with my therm and pcv/grommet, and now i cant get that DAMN PHH back in place, i also cannot access the middle bolt to move the metal pipe easily!!! WTF even after buying some $100 flex head ratcheting wrenches! im hoping to finish it off tomorrow and add my toyota red/distilled mixture and put fuel filter and starter back in! Damn this PM stuff could be a full time job! Sorry bout the thread jack!
I had the same problem. I am sure the info was there about the middle bolt but I must have blocked it untill I was into the job. I got it without removing the middle bolt but requires alot of creativity.
The key to the bolt is a 6" long 1/4" drive Craftsman wrench and a short short socket. Get it on the bolt, but no leverage... Use another wrench as a lever to push on it.
Hope this helps. YMMV.
i finally "finessed" it into place and put the top bolt back in and got her all patched back up no leaks 2 more flushes of radiator and block and added the Red stuff 50/50! there seemed to be quite a bit of sluge in the radiator! it took me nearly 8 flushes of clean tap water to finally start getting semi clean water out!:eek: I am putting the fuel filter off when my next oil change is due!! now that i have done the PHH i feel a lot more comfortable if i had to do it again! i could never have done it without the ih8mud site and search!
my father inlaws garage has a 3 foot pit in it for changing oil so i can use that when ever i need! makes it easier to get under the rig!
