It's not necessarily an IFS thing so much as a 100 thing. If the minimum clearnace points are front, rear, inside/outside then lifting won't help change those. Lifting can help reduce contact above the tire, but that's not the problem with the 100. You run out of clearance in basically all other directions before you make contact above so lifting is largely irrelevant for tire fitment on a 100. As @MountaineerLC says above, you're also not necessarily changing the bounds of wheel travel unless you also add a bumpstop to reduce travel.
Forged wheels in any offset you desire:
BRAID Forged GT 4x4
Desert Racing, Gravel Rally, Off-Road Racing, Overland, Rallycross, Rally Raid, Street. [split] BRAID's range of Forged competition wheels are designed to survive the rigors of competition but are equally at home on the street. BRAID forged wheels are made of a light alloy enabling optimal...braidusa.com
or
BRAID Forged UR4
with beadlock: BRAID Forged UR4 Beadlock A - https://braidusa.com/collections/off-road/products/braid-forged-ur4-beadlock-a?variant=42572337774747
Each!? Wow haha. I thought the Hutchinsons were overreaching a little.
