Parting out 1984 FJ 60
I am in need of some sheet metal, and hope you can help.
First off I need the following metal outlined in red (basically I need it from the drip rail up to the "flat" of the roof from the rear corner to past the beginning of the rear door) if it is not rusted out-- it appears good in your pic but want to verify:
I could also use a portion of the cowl panel-- it would require removing the windshield though... I need a portion of the cowl and then the "lip" that the gasket fits over.
If the sheet metal works out, I would also grab the ashtray off of you. ;)
Let me know. I am in Ventura County right off the 101. If you are swinging north from San Diego later this month, I could always meet up off the 405 or the 5 to facilitate a transaction.
Thanks.
I have the windshield out. (It was broke before I started, I swear it was.)
Here is the pics as promised.
The pittom pic is the lower corner. It is just surface rust where the paint is thin. No scaling or no pits ext.
The dogleg is the section that connects the rocker panel and the rear q-panel. It makes up about 1/3 of the wheel well. I would gladly take both if they are not rusted. pm me please.
Thanks
Ben
I talked to a buddy last night....mentioned that he talked to somebody from Cali with a RHD 70 series on a trailer around sandpoint ID, would that of been you?
Drivers side rear quarter emblem
I am looking for the badge that says "toyota Land Cruiser" that goes on the rear quarter on drivers side. Thanx
Still got the steering column? More specifically, I'm looking for the multifunction switch IN the column. I'll try to check back, but if you have it, PM me please. Thanks!
