Parting out 1984 FJ 60
hello there. I dont know if you overlooked my post or what but was inquiring if you had the side opposite the key for the ignition. essentially it is in the column with the wires coming out.
thanks
bryon
I read it and I have it.
I travel during the week and will be tearing into things this weekend when I'm home.
thanks
bryon
I'm know it's there somewhere so I got a picture of it. What part do you need?
(This is a 60 and not a 62 with cruise control.)
I need,1 passenger fender, no rust (no inner wheel well needed), a good(brown striped) front seat cover and cushion, 2 rear shoulder seat belts w trim if you have them, 4 good bumper ends(1988),1 working power antenna, 4 good mud flaps, 1 properly working OEM alternator, 1 front grille if it's perfect, 2 OEM tail lenses, 1 Valence, I believe it is the metal trim below the grille & between the fenders and the hardware needed to tighten up my auto shifter..shipped to 02125 thank you, Joe
This is a 60 and not a 62.
Please see pic below. If you want a more detailed pick let me know. (Please see #1 Post.)
I need, a good(brown striped) front seat cover and cushion,
I'm selling as a set. Ray N has 1st dibs and Rigger has second dibs on them. I will split and part out only if I have too.
I need, 2 rear shoulder seat belts w trim if you have them
I'm selling as a set and VT Cruiser has dibs on the rear set, if I can split them I will.
I do have the rear trim for the set belts.
I need 4 good bumper ends(1988)
Don't have. The two front one are good but they go with the bumper.
I need 1 working power antenna, 1 properly working OEM alternator, 1 front grille if it's perfect, 1 Valence, I believe it is the metal trim below the grille & between the fenders and the hardware needed to tighten up my auto shifter..shipped to 02125 thank you, Joe
I do not have. (This is a 60 and not a 62.)
I need 4 good mud flaps thank you, Joe
Rough shape to good shape, do not want to represent them as in great shape. I will get pics. $50 if you want the entire set.
I need 1 properly working OEM alternator, 1 front grille if it's perfect, 2 OEM tail lenses, 1 Valence, I believe it is the metal trim below the grille & between the fenders and the hardware needed to tighten up my auto shifter..shipped to 02125 thank you, Joe
Nope.
I need 1 front grille if it's perfect, 2 OEM tail lenses, 1 Valence, I believe it is the metal trim below the grille & between the fenders and the hardware needed to tighten up my auto shifter..shipped to 02125 thank you, Joe
Nope, it's a 60 and not a 62. The grill is in really good shape but not perfect. It does not have any broken tabs but has been sand blasted by road sand.
I need 2 OEM tail light lenses. Joe
Nope. Kurt at Cuiser Outfitter has them for $25.00 per set used.
I need Valence, I believe it is the metal trim below the grille & between the fenders and the hardware needed to tighten up my auto shifter..shipped to 02125 thank you, Joe
Nope. This is a 60 and not a 62.
i'll take that a/c control bezel even though it's cracked (mine is worse) if the price is right and you still have it. shipping would be to 85745. let me know. thanks.
if you have a way to cut out a chunk.... how much would you want for the metal from side to side in rear about a foot deep.
Let me take up the carpet and get a better picture.
Here are the pics.
The road cone indicates the worst spot. I scrubbed it with a wire brush.
How does $5.00 sound? I can mudship it.
I will drive my big rig to tucson on the 20th and be in Tucson on the 21st and 22nd, Phoenix on the 23rd, driving to San Diego on the 24th and I will be in San Diego the morning and early afternoon on the 25th and them heading north.
thanks.. that's the spot of rust i wanted to repace. I guess i'll pass. thanks for looking
I have not looked under the rig at that specific piece.
Is there a way that you could take the left section or center from mine and replace the right section of yours. The hinge mounts might be the same.
Just a thought.
