Parking Brake
Spring Tx
Hello all! I was wondering if anyone could tell me how to tighten the parking brake, the brake on the back of the transfer case. Thanks!:confused:
you can turn the adjusting nut on the brake assembly. I think if you turn it counterclockwise it tightens. I just had to do this. The adjuster is towards the front of the truck.
any pics of what this looks like?
Here ya go:
Damn poser that's a clean e-brake, I gotta get a speedisleeve for mine. I adjusted and adjusted and it worked for a little bit but that tranny fluid has ruined my progress.
Hijack...
Steve, what type of rubber grommet are you using to seal that adjuster? Looks great.
Dom-
The cover is an OEM piece, 46577-35010.
Don't know if they are still available, as I purchased some many years ago, and I think that was my last one. :rolleyes:
SOR includes it in their parking brake service kit, along with the rear output seal for the transfer case, as I have installed a few of those for customers over the years...
:meh:
You can make your own grommet/dust-cover using neoprene insertion-rubber and wad punches (if your on a low budget like me). And the beauty of this is - This cheap method lasts WAAAY longer than OEM.
And here are some pictures from the manual for the thread:
Yup, if you can fit the 10mm wrench on it, you found the adjuster.
SOR part # 076-10- $3.74
I know this is an old thread, I am happy to find drawings here. If any of you have the method or tool to pull the drum off I’d appreciate it. I may need to get the speed sleeve on here and a new seal. Losing too much gear oil.
Once you have the retainer nut off, the drum usually slides off pretty easy, especially if it’s been leaking lately.
Two types of nuts: castle nut and stake nut.
Castle nut is pretty obvious: remove cotter pin. With the stake nut, you will have to punch the recessed part of the collar out, unless you have a good impact gun.
