- Joined
- Apr 7, 2011
- Threads
- 25
- Messages
- 130
So I've had some significant wobble in my steering wheel for a long time, usually between 30-40 mph. It used to be full on death wobble, but after replacing a bunch of other junk, that has mostly gone away in the worst sense. But it still wobbles quite a lot, basically all the time. Why did I replace a bunch of other junk rather than the panhard bushings? Because for YEARS I've been asking shops to replace the panhard bushings, and they've poked at the panhard with a pry bar and told me they're fine.
So I finally went and just took the dang thing off myself and I'm going to press out and replace the bushings to see if it fixes things. This will be my first bushings job, so I'm honestly not sure how bad these are, but they look pretty bad to me... I'm really hoping that this will finally fix that steering wobble!!! Anyway, take a look at these bushings and let me know if I'm crazy or if these are shot and replacing them should help a lot with steering wobble - s***'s been driving me crazy for YEARS. I will update once I've replaced the bushings and reinstalled the bar, with whether or not things are fixed or at least significantly improved...
Fun tip for anyone removing your panhard bar - crank the wheels to passenger, and it makes everything so much easier. I couldn't get a breaker bar on the frame side at all before cranking the wheel, and on the axle side the bolt came most of the way out and immediately got its head stuck against the tie rod. Cranking the wheel made plenty of clearance for both issues.
LCA bushings are also on the menu in the near future to try to finish tightening things up in the front end, along with the knuckle job, and eventually motor, trans, and body mounts... Maybe some day she'll drive like a Lexus again...
