Paint supplies?
Trollhole
THC
Supporting Vendor
Moderator
Mauldin, SC
Website
forum.ih8mud.com
I'm fixing to start the body resto of my cruiser and need some advice on surface prep supplies and where to get them. I'm replaceing the rear sill and rear fenders and am going to strip all the body parts down for individual painting. The cruiser has about 3 coats of paint on it with the top coat in pretty bad shape. I'm thinking of bringing it down close to bare metal or at least close to it. Sand blasting is not an option right now since I really want to do it myself. So I picked up a 60 gallon IR and a 90 die grinder and a 6 inch dual action sander.
1. So whats good for getting the old paint off?
2. What type of filler should I use for imperfections?
3. What should I use to get it preped for paint?
I'm probably going to do single stage Urethane. I'm thinking of using PPG paint. I have a good friend who has painted a couple of cruisers an says this is the way to go. I trust him. But wanted to make sure this is the best bang for my buck. I'm being told paint including primer will be around 750$ Does that sound right?
4. So what kind of primer should I use?
5. What should I follow all this up with to get the orange peel out?
6. And where is a good place to get all this stuff.
Thanks.
I sand blasted mine , a D-Awith 36 grit and the die grinder should work lots,a work JC
aircraft stripper works well for the large areas. but if you dont want to deal with the mess DA with 36git works fine.
I use 3M stuff.
Polyethethylene filler is great stuff. much better than your dads old bondo.
Filler for large stuff. Etching epoxy primer is the only way to go over bear metal. After youve blocked it with 200 and you still have low spots that when you can use some glaze. Thinner than the filler and dries quick so you can keep moving on your prep.
I use DuPont chromabase line of paint/primer etc.
For all the prep work you'll be doing yourself, I would suggest that you don't go cheap on the paint system.
I have used PPG on my 40's with good success, but the paint and primer was more than $75. On one vehicle, I used Deltron (I think), the other I used AUE-300.
Go to an automotive refinish outlet and ask for prices, but before you go, look online and read some datasheets. You'll find that top coats and primers are made and tested together. The datasheet for the topcoat will list the compatible primers. Datasheets will tell you how each paint system compares and let you know what the tradeoffs will be (abrasion, salt spray, UV resistance, etc.). You will get what you pay for.
Primer cost me about $40 per quart. Top coat cost me about $90 per gallon. You'll need urethane reducer, air dryer, etc. so the bill for materials goes up fast.
Good luck and have fun - it's a great learning experience.
Sparky_Mark said:
I have used PPG on my 40's with good success, but the paint and primer was more than $75. QUOTE]
you mean 750$?
one bad thing about blasting a body. If you give it to any joe shmo they will heat the metal up and warp the body panels. I'd rather not do that and if I were going to have it blasted it would be with walnut shels or soda. Both are expensive to do.
Here are some links that will help you out.
Auto body info:
http://www.autobodystore.com/class.htm
Fillers good prices (Evercoat is good, their metal 2 metal product is great):
http://www.sjdiscounttools.com/
Rust protection:
http://zero-rust.com/
http://www.zerorust.com/tech.htm
http://www.mfgsealants.com/
Discount paint supplies:
http://www.smartshoppersinc.com/
Kirker paint:
http://www.kirkerautomotive.com/
Other paint info:
http://www.unrealshadow.homestead.com/painting1.html
For paint removal try a variable speed 7 inch grinder at 1000 rpms or less with 80 grit paper. It won't heat the metal up much if you keep it moving. Primer the truck with a self etching primer on the bare metal. If needed follow with a surfacer/ sealer primer. If using a single stage, consider adding some clear to the color in the final 2 coats to give finish more shine and protection. Be sure to get a respirator, plenty of rags, prepaint cleaner/wash, tape/paper, 320/400/600 sand paper, acetone for cleanup, air filer/watertrap. Have fun :cheers:
ditto the low speed grinder for removal, and I had great sucess in the past with R-M paints, the limco sprays like a hot damn, lasts and looks good, the diamont B/C is great, and they had another acrylic enamel that was a step up from the limco, but I can't remember the name right now. most of my spraying with these products was painting schoolbusses, lot of coverage, lot of spraying, and it always looked good in the end.
former job description, "painting things yellow"
paint removal can be done with a DA sander, but you have to keep moving around, and keep putting a few fingers to the surface to make sure that you aren't heating it up too much.
there are some pretty reasonably priced small sandblaster/spotblasters available, it really is the best way to go.
clean, strip, sand and prime well, you don't want to go through this again in two years!!!
Marshall,
Give me a few years and i can tell you about Valspar.
That is what i am using on the 45. Tell you the truth though, next time i paint another truck it will be base coat, clear coat for me. To me it sprays better and comes out alot better.
Just my views.
autobodystore.com has an excellent message board
I just stripped my FJ55. 3m makes a hook and loop pad that attches to a 4 inch grinder. they have a scotchbrite pad that is about 3/4" thick that does a great job
albee said:
. Plus $40 to www.paintucation.com for a dvd on bodyshop basics.
+1 on Paintucation, I have all his videos and they have a good discussion forum. Videos are quite helpful.
I use Kirker and it has a really good gloss in the single stage urethane. The only draw back is wanting custom colors. It's only availble in prepackaged gallons. I added some clear to mine to give it more durability. I couldn't tell any diference in gloss between adding the clear and not. I only added about 20%. You can also bc/cc the Kirker urethane. As with any urethane orange peel is a problem that has to be delt with by sanding and polishing. If using Kirker have the factory send you a color chart. Also they now make some candys. I would recomend using the slowest reducer and give plenty of flash time. Figure a min of 2 gallons for a 40 if going SS. Put lots of coats on ,so when color sanding you don't have to worry about burn thru. If clearing figure 1 gallon of clear, 1 gallon, color, 1 gallon perfect prime 2k primer. If the hardtop is in bad shape you might need some polyester surfacer to help fill the craters. Not a bad product for the money. I used Mack white. I may buy some more and 2 tone the hardtop, so it don't look like a loaf of white bread.
:D
Brad
I second the vote for RM products. I spray Diamont and Glasurit at work. Their Limco is a good single stage, but man does it smell horrible. I've got a gallon of Limco black for spraying bumpers. Utech also makes a real good single stage. I used it on my truck 5-6 years ago. It's held up well to trail damage. Still has a decent gloss considering I haven't washed or waxed it since I painted it.
I second the vote for Rage. Evercoat Metal2Metal is even better, although more $. Metal glaze is also good and can be used to thin out fillers like Rage Gold. Paints are like everything else in the world. Some are cheap and not worth the money, others are expensive and your paying more for the name. Some are good values. If you are a first time painter, go with a less expensive paint with a good reputation or reviews. That way when you make a mistake (you will make mistakes) you can afford to correct it. It's really a bummer to have lots of money tied up in materials and find out you have to buy more to fix something. Also remember some of the more durable paints may get really hard quick, thus increasing the work to rub them out. Generally most experienced painters on the boards say a bc/cc is easier for first timers than a ss. But of course that bc has to be perfect before you shoot the clear.
Here are some more links that can help:
http://www.autobody101.com/forums/index.php?sid=529948cd35e1a127f178a4f8ee783128
http://www.systemoneaps.com/new for 2006.html
http://www.properautocare.com/exteriorcare.html
:D
:D
Thanks,
Forgot to mention the Metalglaze :doh:
Iam pleased with just about anything Evercoat makes
