Paint Code
Charleston, SC
Guys,
What's the paint code for "smurf blue" on the FJ55's? I can't find it anywhere, unless it's called something else on the CCOT.
thanks,
Stuart
Mine is a 72 FJ55. It was definitely the lighter blue color originally (along with the white). I found the old blue around door jams. When I think royal blue, I think Duke Blue Devils. Enlighten me. I'm taking her to the paint shop soon.
Thanks
72 was a transition year between Royal Blue T452-2 and Royal Blue 822 I would look at your production date and if it is before 9/71 go to the paint shop and see if they can find T452-2 if it is after 10/71 go with 822. Both of them were with Cygnus white 012.
Ryan.
couple more to check for you as I just went through a very painful learning process with my 74. Check 808 and 1208. They should be the same mix with the 1208 being an older code I think. This is horizon or horizontal blue. I ended up with something that was custom matched and looks more like capri blue to me which is bizarre as my rig has original paint. I guess the short lesson for me was go to a good paint shop with a part off your truck and let them figure it out. I elarned this after painting most of my stuff the wrong color. :)
Stu,
Here are a few photos from a thread on paint codes. The first two both claim to be 857 (medium blue) and the third is 808 (horizontal blue). Hope it helps.
Guys, thanks for the input. My truck was built in 11/71. So should I go 822? Here's a pic of the color I believe to be the same as mine.
