Pac Rats
Santa Fe, New Mexico
I am looking into buying a stock 1975 FJ-40 that has sustained wiring harness damage. How would you create a simple motor and drive train test harness? I am thinking about sending power to the carb choke, idle cut-off solenoid, alternator, coil, and starter via a relay switch. What do I need for grounding and isolation of anything that might cause trouble if it gets voltage.
I'll give it a shot... But @Coolerman is the expert... and he can help you with harness fixes, etc.... If he has time.
The starter case is grounded to the passenger side frame, near the clutch slave cylinder.
The battery negative grounds to the passenger side frame, behind the right front wheel.
The "rear harness" grounds to the passenger side fram, next to the transfer case.
How bad is the wiring harness damage?
If you're trying to gauge powertrain operability, prior to purchase, and just want the most basic electrical, so you can drive it "illegally" (no brake/tail/signals, etc.), The following are needed.
  • Momentarily power the starter (positive battery cable connects to starter lug), to start the truck... You probably have a 2nd wire on your starter too... you could push/pull the truck to start it.
  • If you plan to drive any distance, you will need the alternator wired in... The battery won't run it very long on its own.
  • It probably has an external voltage regulator... You will need this to control the alternator's power generation.
  • Coil probably has a ballast resistor and an igniter... all will be needed... Along with connectivity to the distributor.
  • The carb may have electronics... Like idle solenoid.
  • Existant emissions controls open a whole new world of huh?
  • The tranny may have a switch... High throttle position switch or some such thing... You can probably test drive it without this connected.
There's a lot of other wiring and electrical connections, but I can't think of anything else that would "play" in this endeavor... I'm sure I'm forgetting something...
You'd definitely want to disconnect the harness completely and leave it out of the test...
Mark (@Coolerman) also has electrical schematics, by year, on his WEBPAGE
Hope this helps...
So, will Coolerman's rolling chassis harness work with an alternator/regulator belted to the crank pulley? Where is the fuel pump on the diagram? Will the truck run without juice to the Vacuum Switching Valve? What is a Computer T.P. that it is connected to? Does the '75 have a pull choke?
The FSM/Haynes diagram confuses me regarding the battery. The bold line connects to the starter, but the whole truck seems to run off the alternator except for the ammeter.
This is how they do it in Louisiana:cool:
@gator25 :cheers:
OEM fuel pump is mechanical, not electric.
My '78 has a pull choke, so... I'm pretty sure '75 does as well.
I desmogged my '78 and don't remember emissions specifics anymore... But, if it's still smogged, it shouldnt prevent it running... But, it may run rough or not have much umpf.
Probably gonna have vacuum leaks...
If you can get it started and up to temp, I'd get compression tests right away.
