P0171 real time help
Woodland Hills, Utah
Time for Emissions/safety inspection, so 97 LX450 w/250000 on clock starts throwing 171.. too lean code.
Need some smart mud guys to help this poser mechanic to maybe confirm my conclusions.
On blue tooth OBDII reader, Comparing it to my 97LC the only difference is the LX has long term fuel trim is idleing at 9% up to 17% .. at cruising speed 25 to 35% FSM says limits are 0 - 20%. ( LC is running -2% to 4% idle with 4 - 15% while driving.) LX Has about 20% decreased power but surges occasionally with normal power, simultanious with long term fuel trim reading normal.. then goes back to +25 and power loss/hesitation. feels like electrical short
THings I have checked:
1. O2 sensors read in spec for resistance per FSM. Reading rich during running generally .4 to .8v with occasional going down to .1-.0v volt during deceleration. ( both 02's) O2 #one is two years old OEM.
2. Only exhaust leak is very small leak in donught between cats. Y pipe has been welded at the V and appears sealed. No sound or indication leaks at manifolds.
3. Coolant Temp sender seems to work, reading 179 to 193 during driving in 80s to 95 deg f.
4. checked intake hose, vacuum hoses for leaks.
5. Switched MAF sensers from cruiser to LX. No change
6. blocked vacuum line from brake booster to check for leakage in booster.. no change ( booster hisses when below about 20deg. F so its about time for new booster.
7. pinched off fuel return line from pressure regulator, no change ( I dont have a way to measure fuel pressure). Is it worth the time to drive 30 mins. each way to HF to grab their fuel pressure kit?
8. Switched fuel pump relay from LC to LX no change
9. Switched fuel pump resistor from LC to LX no change.
10. To my knowledge , no injector replacements or service ( bought LX three years ago with 160K slimy dealer, no PO history. (run CNG mostly since bought. so injectors run a few seconds at each startup, or when I run out of CNG. ( Run Seafoam in gas 25% of the time since a 1/2 tank of gasoline lasts 3 - 5 months)
11. fusable link failed/replaced two weeks ago. intermittant stumbling. New one solved problem.... Could that have fried ECM?
Current thoughts...
I have basically come down to fuel pump, but I am still confused. It is 98% of the time running bad but it kicks in then out of normal operation more like a bad electrical connection during acceleration ..Dont pumps just fail altogether without any intermittent effects (seems like a clogged in tank filter plug would not the the intermittent run right moments) . or at least act consistently? I have a denso pump on the shelf but I hate to dive in to a pump replace this weekend if I can avoid it.
Could this be coming from the dreaded cooked wiring harness behind the EGR valve?
any thoughts or advice?
Thanks in advance.
good suggestion but I Failed to mention already cleaned and adjusted all related connectors while taking FSM test readings, but.. New update:
I figured I might just as well dive in to replacing the fuel pump. with 250K and no maintinence history prior to 160k I figured I would do it, even if it ended up just being PM. when I got inside the tank, it was pristine. clean, no crud, no rust. pulled out the pump and it was discolered. Looks like it has been getting very hot ( by the way I am ocd on always having at least 1/2 tank. Never seen my orange warning light.
When I went to carefully disconnect the wiring harness from the pump it crumbled in to dust. heavily burned on the 12 v side. I ordered a new pump bracket that comes with the wiring harness, but even with fed X I bet I dont see it till wed.. Burnt to ashes wiring connector inside the fuel tank raised my eyebrows. Glad its a positive pressure tank without oxigen in the tank I'll try to attach my first ever pic- hey, it worked. cant figure out how to erase the duplicate. I'll post an update when I get the parts and put it together. Bad connector, hot pump look suspicious but I wont know till I have it put together. Something as critical as the wiring inside the fuel tank I dont want to try inventing some makeshift wiring work around and have it fail on the trail so I will wait till the part comes in. Hope it's not backordered back to Japan.
I just went through narrowing down the same issue with a recent P0717 error last week. My LTFT numbers were similar to yours as well. Turns out my upstream O2 sensor reached its end of life w/ 217k. I typically purchase OEM parts only but decided to order Denso O2 sensors from rockauto.
Time will tell if they are as good as factory but seem to be working perfectly fine and it fixed my issue.
Zane
I should have noted that my truck was running perfectly smooth prior to and after it threw the P0171 code, where it sounds like yours is running poorly at times.
I am leaning towards to the fuel pump just from looking at how badly burned the contacts were connecting the wiring to the top of the pump. That would explain the intermittent power surge which coincided with the 02 voltage bouncing at a normal range with the long term fuel trim back to normal. few seconds later the power loss ( about 205 ) returns with the 02s reading .4...or . 6 bouncing up to .8 or .9. I certainly see a condition with the pump that could explain it, but not absolute till I get the parts.
On my 97 LC I have 267000 on the clock with original fuel pump, original 02s ( havent touched a single fuel/OBD system anything except a 402 code which was the plugged port through the intake manifold. drilled it out and cleared the code)... sorry Head Gasket club... original head gasket too. On the LX 450 I did a head gasket and put in a denso 02 #1 at that time... has 90,000 miles since. I think I'll go ahead and order a set and get them here and if the fuel pump fixes the problem I'll have a set on the shelf ( since I am on borrowed time anyway with both vehicles 02's.) I dont understand how the 02's actually work so I cant offer any opinion about a possible intermittent nature on an 02. All my connectors look clean and shiny with no corrosion. I suspect if it was a wiring problem... or worse, the dreaded wiring harness next to the EGR, it would be a total failure mode, rather than just running lean.
final result. I installed a new fuel pump and the long term fuel trim went back to normal and it only took a few minutes of running to be ready for emissions testing, values now mirror my 97 LC. the interesting thing was the fuel pump was putting out sufficient flow/pressure for the long term fuel trim to compensate and keep it running with fairly normal performance but the 171 code alerted me to the problem. My other 80...the 97 Lc has 266000 miles on the original fuel pump. it was an easy enough job i think I will do it a PM
