I sent my injectors to RC Eng for clean up and maintenance. Removal and installation went fine.
However, after about 60 miles I got a P0171 code. I clear the code and it comes back every 30-40 miles.
After about 300 miles I got a P0401 code. I've had this code only twice.
Finally just recently, after about 400 miles I got a P0133 & P0130 codes (just once).
I read threads, searched, and looked at the manual. I checked the basic stuff (mainly visual, cracks, leaks), but I keep thinking that everything was perfect before the injector service so I keep thinking that the issue has to do with something that I did or did not do.
Also, even with the codes I do not feel the engine running bad, so I'm assuming it has to be something very subtle.
A couple of things that I did not do are changing fuel pressure regulator, and I did not change EGR gastket.
Note that the P0171 code takes a little to come back on, is that normal when getting this code?.
Also, the fact that I got P0401, P0133, P0130 tell me that there has to be a common denominator, and I have to think it has to do with my injector service.... or is it just coincidence and the issue is unrelated ??
Anyhow.. I wanted to ask before I start hunting down the issue.
I appreciate any input. Thanks !
