ARCHIVE Owl plug-and-play LX courtesy/puddle replacement and rock lights
Do you know if they will work with a 2001 LX that doesn’t have running board lighting?
They will. You'll just need to check that the plug for the running boards is still there. Even though yours doesn't have lights, it still has the plug and all the wiring. Look for the plugs coming down from underneath the front driver and passender side foot wells.
I can provide the factory plugs that you can crimp onto this set to make them plug and play.
How much? :)
Hey at that price I will take 10!
@TravisLaves Pretty sure that means $10 for the plugs shipped to Oregon if you buy the gen 1 set that is being sold.
Hahah I was assuming something similar - $10 a piece I would easily take a handful.
The original price was around $120 if I remember correctly? So is this $130 shipped? Comes with plugs and plates?
Is there anyway to get a version 1? Correct me if I’m wrong but on the version 1 the lights came on with the unlock button correct? I noticed that the description on version 2 states that it only turns on with the doors. Maybe I misunderstood.
I prefer the version 1 for my needs if this is the case - is that possible?
John
Disregard - I see your comments now on some models that is the case. I have an 06 so mine should still turn on via key fob. I’ll pre order a v2 then :) thanks!
@Ramathorn15, do these work on LCs now?
Hey everyone!
I'm discontinuing these lights to focus on my other projects. I had some inventory left that I never assembled, but did over the weekend.
I'm selling the last 3 sets of the LX plug and play kits at a liquidation/4th of July special of $140 as opposed to the original $175.
Get them before they are gone as I will likely never make them again!
Owlexpedition.com
Thanks for the quick orders! There's one set left. I leave tomorrow for vacation until Sunday so all the orders today will ship in the morning. Just need the last set sold and they will all go out tomorrow..
Got the last one!
So I’m at a loss. I’m getting 12 amps on the drive side and nothing comes on. 4-5 in the passenger side. Nothing. What am I missing? Also doesn’t help that my key fob stopped working. It’ll start the car but will not unlock or lock remotely!?
Hmm. Do you mean volts? If not, measure voltage at each plug. I had a similar issue when I had a short in an experimental relay. Turned out to be one of the fuses in the pass side footwell.
Grab a 9v battery and a couple peices of wire and make sure the lights are working. I tested every set in the last batch, but could have had an issue when being packed or shipped.
