- Joined
- Apr 10, 2005
- Threads
- 17
- Messages
- 82
Still pondering cheap/easy cures for the SOA wrap I read so much about. After watching tacomas pull away from stop signs and watching the overload leaf drop behind the axle due to torque- I wondered if the same might work on the 40. I have stock springs and I welded on my perches for a non-dbl cardan driveline. The angles apear to require the dbl cardan so to rotate the pinion up I have some 6 degree shims for now.
As the picture shows I am looking at puting the shim between the OL leaf and the rest of the pack. This will put the OL leaf just under the pack foreward of the axle. Seems to me most of the wrap is on foreward excelleration and I am no speed racer.
I would also cut the back end of the OL leaf at the white line.
So will it effect travel? Im sure it will. On compression I think it will keep the pinion pointed toward the transfer case. There should be little effect on droop-
Well- I can take it. I understand the tried and tested triangular design with a shackle. I just need to get this thing rolling.
Thanks
Thanks
