Overheating Problem
:bang:
I still have a problem with my 1996 80 series landcruiser 1fz-fe motor. It keeps overheating on me. So far i have replaced the viciouse clutch fan and thermosat, flushed out radiator and filled with the best stuff i can buy. i have also fitted a dogwatch temperature alarm which i have set at 90 degrees celcius which seems to be nearly boiling point. After driving up a hill on a relative cool day it will get to 90 degrees but usualy stays between 81-83. I would think that the only thing to do now is change the water pump
Can you please let me know your ideas on what i should do. Maybe there is a trick you guys no that i dont.
Kind Regards.
Chad
Well I had the same issue. Turns out I had a bad radiator cap. Solved my problem.
:bang:
Kind Regards.
Chad
Your temps of 81-83c or 180F are quite good and most engines run temps in this range.
I dont have a 1FZ manual but I have one for all the other toyota engines and they are all in this range.
A new radiator cap is always a good investment. If it cant build pressure it will boil at lower temps .
My radiator didn't show any signs to the Toy technician when they flushed it but 90% of it was clogged when I brought it back in a week later. You might want to either have the radiator serviced or replaced. Oh and don't pay out the WAZOO like I did to have them remove it. Remove it your self and it's not all that expensive to have it serviced.
x2
Even at 90c you are only at 194F. I don't have the FSM with me but IIRC you should start getting REALLY worried around 226F or 108C (Edit: it is --> 226F AC Cut Off Threshold). I've only seen my stock gauge move from its normal operating temperature resting state (~150F-210F) on two occassions and that was once the temps got above 210F-215F per my Scangauge II.
Personally, after my flush of the coolant system and with a new fan clutch the max temp I have seen yet was 206F or ~97C. That was pulling a popup camper into a stiff headwind/crosswind across Utah on about an 80F day uphill where the max speed I could hold was 55mph with the pedal floored :eek:.
Like others stated, if the coolant is boiling at the temps you are seeing today I'd replace the radiator cap and see what difference that makes. Cheap solution if that is the problem :steer:
The 1996 FSM says the thermostat starts to open between 80-84*C, and should be open 10mm at 95*C (is that full open???). So I would think anywhere between 80 and 95 should be ok. Someone feel free to correct me if I'm off base.
