Overheating diagnosis
I started Replacing coolant hoses thinking diagnosis is Thermostat being stuck and while at it I might as well change hoses.
While talking to @Kernal, I realized I might not have made right diagnosis so starting one more thread.
My current problem is engine overheating: When temperatures start rising it doesn't stop at mid-way goes all the way to red mark at which point there is puddle of coolant on the ground (under engine block towards driver).
I've done following
1. To make sure it's not due to low coolant level:
refilled coolant when it emptied first time (assuming I was running on low coolant for a while), then refilled again on second time
2. To make sure gasket is not blown:
Just checked if tail pipe has white smoke, I don't see any (apart from very early morning due to condensation)
3. That almost only leaves Thermostat stuck (or maybe pump not working)
Car details:
LX450 (US) 1997
210k miles
Should I check something else?
Thanks
Could be as simple as a bad radiator cap. Fill it up, fire it up, warm it up till it starts leaking and identify the source. Where is the wet spot on the motor, firewall, radiator, etc?
oh ok some more details:
wet spot = stream of coolant under engine towards driver side, enough to get rid of all coolant in about minute.
temperature needle goes to red and stays there once temperature starts rising.
PHH and throttle body cooling lines are both right in that area. Look over your heater valve also. They tend to die of old age by now. Cheap on Rock Auto. We have changed dozens of them!
PHH. Only tool needed is a pair of vise grip fingertips. Only the little guys in Japan have those though.
X2 on the hose under the throttle body.
