On first start after installing the fan, it roared loud then went back to its normal weak blow.
Tried driving it for an hour. Never heard it roar again. Temp outside is about 50 to 60 F.
Could the engine temp be low enough that it did not engage or i just did not get enough fluid in.
I will look around for more write ups about the eaton fan clutch mod.
The normal mode is a roar when first starting. When idling in hot weather the fan clutch will start to heat up and the fan start to spin at water pump speed, if you rev it then you should hear it roar but only for a few seconds.
If not warm out throw a blanket over the front grill.
My electric version does not come on with normal running around town, if it is left idling for quite awhile it eventually does come on, but the heat is shed within a few seconds and it goes back off.
regards
Dave
