Overflowing Gas Tank
PNW, WA aka wetside
Decided with gas prices going up $0.25 a week that I'd fill up now rather than later. I was around 3/4 empty and still being on the first tank of gas since buying the 40 I didn't want to push my luck.
So I went and filled up w/ 11.53 gallons. Is the capacity for a stock tank on a 1978 FJ40 16.4 gallons? That figure comes to mind for some reason...
When the pump stopped I began filling my 1g blitz can for my lawnmower, I didn't try to squeeze that extra 1/4 gallon into the tank.
About 10 secs after the pump stopped, gas began to seep back out of the gas tank from the fill nozzle. :doh:
What caused this? I'm guessing pressure, but is this normal? When I got back into the 40, I could hear the gas swooshing around, so it would seem there was plenty of room in the tank.
Just want to know if this is a normal occurence...:princess:
I'm pretty sure my 78 only held about 12 gallons, not 100% sure but pretty sure. Gas burpin out after filling is NOT normal. Maybe your vent hose is plugged?
I just dealt with this on my rear tank and fixed it. The stock tank fill neck should have a port/tube that should have a larger hose attached which routes to the top of the gas tank. If it does not (modified) or it is capped, you need to run a new hose from that port to the top of the tank and it will work fine.
Noah
you know.. I have an auxillary man-a-fre tank in the rear and do NOT have a port/tube in the neck down to the top of the tank and do not experince this issue in that tank. the top of my aux tank does have a vent hole at the top, but mine is and has always been capped and I just recently removed the tank, cleaned it, painted and lined it, and then recapped it.
I could see the reasoning for running that tube to the fill neck, but mine never has had it. Also, my neck is flexible rubber, so I can't really drill into it and add a tube if I did want to do this. I wonder what would happen if you just added the tube off the top vent and just ran it up higher than the tank? still vents, no fuel should leak out either you think?
BTW, my issue with my rear tank is that the neck is at such an angle that the newer style nozzels do not work well with it so i need to hold the nozzle to fill the rear tank.
just as an experiment..
I took off the tiny cap that capped off my vent hole on my man-a-fre and hooked up some clear tubing (used on radiator overflow) and ran it up to the top of the fill neck zip-tying it along the fill neck. thus, the top of the tubing is inches higher than the tank... but I did not want to drill into the actual fill neck.
I got to thinking that maybe the issue I claimed to have with the neck being at an odd angle and so filling the tank was odd as I had to position the nozzel correctly may not have been right. maybe it was that the vent hole was plugged and the position I was putting the nozzel in was to allow air to get by and not to accomodate the nozzel angle.
so, I will report back what this does.
