overdrive?
Most likely a Fairy that would attach to the rear of the transfer case through the rear PTO connection.
Pretty rare bird, and service parts are non-existent.
That is a bit much for me...considering you want a 420 for the low gear and you can find them for a couple hundred max...a new adapter will be 400.00us max...the tcase you can find all day long for a couple hundred...
The fairy is a novelty....
You can get into an NV4500 cheaper even with adapters...and will have ten times the reliability and drivability compared to that...
:beer:
Anyone hear of/run an old british- made overdrive that goes "in" the transfercase (3 spd). Any problems or positives. Have the oppurtunity to buy a sm420, overdrive, and 3 sp TC, but have never heard of this kind of overdrive.:rolleyes:
I've had exposure to several Fairy overdrives...as a word of warnig..... DON'T GO THERE!
The one on my 1965 Series II 88 Land Rover works fine, and allegedly there are still serviced pieces for them, but the only ones that I have seen or heard anything about for the early one piece case on a Land Cruiser were broken and needed gear pieces that were no longer being made.
Yea, parts are still readily available for Rovers, from what I understand... but one will be most likely be left standing out in the cold as far Land Cruisers are concerned...Although at one time I hooked-up with a cat outside of Melbourne, Oz that had a stash of gears and such, but that has been awhile ago... he was a old dude at the time, and maybe dead by now...From time to time I see them in classified ads, listed as, FREE! to good home or PLEASE! take this thing out of my life... Anyway I have a couple of carcasses buried on the back 30 if that's any indication....If anyone is interested in them? Maybe we can do a resurrection....I dunno tho... better off left in peace... bad JuJu tends to follow the Fairy OD....
I tried to post this before so I apologize if it is repeated .....
I wanted to go with the NV4500 at first but was at a loss on how to gear lower (other than axle which will have 4.88's) while using the stock 3 sp TC and rear axle. That is why I was looking at the sm420 with the OD. I want the OD, but want to be able to do some sort of dual case setup or toybox but don't see adaptors to do it with the 4500........There is the 700r4, which I have in my garage but think it may be too long to do dual t-cases or toybox. :rolleyes:
Well, I ran one on my '73 Series III 109 and it just ran like crazy. Very reliable and very useful for that 4 cyl. diesel. I even tracked down a few "bits" that I needed for it by calling the company in England once. No wait, those parts were for the capstan winch. Sorry. Anyway, the Fairey worked good for me.
Vic
Redlands, CA.
