Outer CV joint C-clip availability?
Goodyear, AZ
I was finally able to separate my outer CV joint from the shaft, but I broke the C clip which holds it onto shaft upon doing so. I do not see this clip available separately from Toyota, so does anyone know if this is a commercially available part from Napa or similar, or does Toyota sell it separately?
Thanks!
Bummer! I'll post the solution if I find one.
I don't think they do (Toyota or Lexus). I never separate the outer as I just repack it in place and work the boots from the inside since it is so much easier to pull that side.
Thanks Dan! I'll check this out and let the board know. Incidentally, the clip is included when you buy a new outer CV, but Toyota didn't seem to want to sell it separately.
@Onefastrx7turbo or anyone else. I am in the same boat needing that outer c-clip. Any word on a part number? I would rather not have to dig through the NAPA parts bin...
It is the same c clip in the 30 spline longfield. You can get them from longfield (have to call or email, not on the site) for about $1. I would imagine any 30 spline birfield c clip would work.
Thanks for the lead, I'll look into it.
Almost forgot to update this. I dropped off my front diff in Golden to get re-geared at Slee so I ran over to CVJ axles and got the clips from them. I took one to NAPA to find a common/local source and they said they don't carry them.
