Orion HD
CruisinGA said:
I believe it refers to the ability to engage the front axle without engaging the rear. Atlas's have this ability. I only just figured it out a few minutes ago, if I am indeed correct.
I have always wondered why anybody would want front dig... It just seems like
1) its a good way to break parts
2) it will tear the trail up more.
If you use cutting brakes you have to be able to just run the front wheels. It gives you the ability to make very tight corners. Mostly used in competition which this thing definitely looks suited for. There are other strange occurrences that it is handy to be able to engage just the front (backwards cookies :flipoff2: )
THe odo looks like it was replaced with a VSS. Also, it looks like they added a coupler like the GM 465s use between the transmission and the t-case. If that coupler has to stay, you would add more legnth to your driveline. Isn't having a short driveline one of the main reasons for going with the Orion?
I'll bet that coupler shaft is just there for the show.....gotta have sumthin in there to keep the gears from floppin around inside.
Didn't notice the VSS...that rocks for me tho :D
In looking at it, it likely wouldn't be too tough to add a disc-type parking brake to the existing rear output....place the rotor over the flange, bolt up the shaft (much like rotors on RDB's are done now), then add a bracket for the caliper. Could be a nice setup, and not hard to fab either.
Front dig is nice for lots of reasons, sharp turning is only one of them...there are times when you want your rear to stay put and slide the front over...times when the ability to heat up the front tires alone may add the traction to clear an obstacle...times when you DON'T want the rears digging in and it's easier to drag them thru under front power.
Front dig is a toy tho, and 99% of the world will get by without it. Stress on the front axle is a definite concern, you'd need to fully beef a Cruiser one so it would survive.
Dana300 cases and the Atlas cases allow you to shift into front wheel drive only...that's what's meant by "front dig". The current design of the Cruiser case doesn't allow the front only engagement option because of the slide-collar type connection to the front output.
Another dumb question.... What is VSS?
Vehicle speed sensor..
So, is a Vehicle Speed Sensor and electronic speedo sender? What does it mean? Can you use it with a stock speedo???????
VSS is a fuel injection specific item, people like me are familiar with it cause it's a common item on TBI conversions and Chev motors. I believe you can also use the pulses to drive a speedo, but not sure how that would work....
I've been reading Poser's Orion threads he compiled here:
Orion Threads=69666
That thread lists this Orion HD thread, but no others. Also, when I do a search of the FJ40 Forum using "Orion HD", the search function ignores the "HD". So, I can't tell if the Orion HD has been addressed more thoroughly on another thread without reading each of the 227 threads that came up. So, I'll ask the questions I have on this one Orion HD thread that Poser placed on his thread compilation linked above since this is most likely the thread folks will find most often when searching for Orion HD info:
1. Has AA actually released the Orion HD?
2. Any change to the front output only accepting a yoke?
3. Any change to the rear flange not incorporating the oem e-brake?
4. Anybody heard of a price?
5. Anybody have one? Installed and tested?
6. Any (God forbid!) "pop out of gear" problems?
AA catalog reference at bottom of Orion page:
http://www.advanceadapters.com/catalog/066.html
If anyone knows of any other threads specific to or otherwise informative on just the Orion HD, please link them here so Poser can consider adding them to his Orion thread list. Thanks.
1- No.
2- No.
3- No.
4- No.
5- No.
6- No.
There is not anything else out on the board about this, as AA does not have them out.
