Yes, they are also including a new front output bearing and seal. I'm going to try to swap the high gear out with the t-case in the rig.Poser said:Ok...
Are they going to send you the stepped thrust washers also?
If not, call back and get them, and put them in.
rusty_tlc said:Yes, they are also including a new front output bearing and seal. I'm going to try to swap the high gear out with the t-case in the rig.
What are you doing this weekend?
Ever been to Reno?
No flyer miles and most of my credit card limit is parked outside. It would be a pro-bono visit on your part.Poser said:Got flyer miles?
Isn't Reno burning?
I have not ever been to Reno.....
Randy didn't think so but agreed that I should check the pre-load when I was done re-installing the front cone. I'm due to get lucky on something.Poser said:You are still going to need to re-set your bearing pre-load on the mainshaft....remove the parking brake and all that...
rusty_tlc said:Randy didn't think so but agreed that I should check the pre-load when I was done re-installing the front cone. I'm due to get lucky on something.
