Oops. Sheered rear axle studs.
GXO
GXO
Moderator
Woodstock, GA
Website
gxor.org
Just thought I would vent on my recent oopsie.
I slid into a rock going up a hill today and sheered the bolts on the rear right wheel holding in the axle. So out popped a nice, clean, and undamaged axle shaft (about 2 inches).
The carrier is intact, I can insert the axle back into the diff, no problem. Locker works, no problem. I suspect I just sheered the studs.
So, the tech:
What is the best way to get the lil stubs of studs left in the rear hub assembly back out? I guess I am going to get a cold chisel and try to notch for a screwdriver or simply work them out with said chisel.
CDan...your puppies hungry? Talk to you on Tuesday (assuming you are closed Monday).
The studs are hardened so be careful if you try to drill them. Did it shear the dowl pins too?
Yeah, the pins sheered too. Not sure on that one...cross that bridge, but I suspect they will come out with a little convincing. Noted on the hardened thing...I am going to back them out of the threads with a chisel and carefully walking them out.
I am just glad it is a full floater so I could get my butt home.
If they don't come right out, get a set of left-hand drill bits. Take your time. They will probably come out with the LH drill bit, but if they don't you have a hole for an easy-out.
-Spike
Thx Spike, that was my thinking as well. I can turn all but one of them by hand to a point just by using my finger nail and a little force. I am hoping that a cold chisel can walk them out with gentle taps until I can get pliers on there.
The pins will probably not be so easy...but hey, dunno until you try! :)
Quick, what size of pipe cap will fit over the FF hub so it can now be armored!!!:hillbilly:
Dan that must have been an exceptionally good shot on the rock's behalf. I doubt under those conditions bigger studs would've held but you could of course use this time to either install the chromolly studs and/or jump up the next size to the larger studs. Not that I'd do either, I'd just order them from Dan and be done with it but it's always nice to bring up more crap. :cheers: Glad you got home with no fuss ;)
Can you weld a washer over the stub and then weld a nut to the washer? I had that trick work 1 out of one time and thought it was pretty cool.
so you sheared all the nuts from the rock then the pins couldnt hold the flange so it spun off the dowels? talk about bad luck.. good luck with the fix. Best of luck. those LH bits are nice to have so you may get a nother cool tool out of it.
I sheered between 3 and 4 of the nuts and studs off...not much left after that.
I didn't even know I had a problem until I had a loss of traction followed by backing up to a "CRACK" that I thought was that clicking birfield I have been wheeling on for months.
Then, I saw the birfs were fine, the diffs were fine, but there was this lil axle peaking out of the right rear :)
I pulled the axle out and the splines were intact and no tweaks, etc...whew. I had images of the Slee dreaded spline failure for sure. Once I figured out what happened it was pretty easy to cover up the gaping hole, throw the axle in a trash bag, and tow strap me out of the trail.
Full floaters are my new favorite thing. Being able to drive home knowing your wheel won't fall off is a nice thing.
Side Note: XL nitrile gloves fit over the rear hub nicely and hold in a grease plug while driving home. I slid one over, duct taped it, and then proceeded to experience the fun of two wheel drive in the woods....SUCKS
You have to check the studs regularly, like every wheeling trip. They tend to loosen up and then you shear them off. Like Somotoy says, BTDT, 15 years of experience :D I don't think it was just the rock's fault.
Anyway, you are most likely going to find that the dowel pin holes are hollowed out. If that is the case you need to relocate them. Take a old front driveflange, then grind of the little domes (on the outside) where the holes for the dowerpins are located. Once you have re-installed new studs, you can use this driveflange as a located to drill new holes for the dowel pins, by re-indexing them to a new spot. You need to remove the hub and do this in a drill press to get the holes located properly and straight.
Also if you run Poly's new rear axle, you can actually install more dowel pins to make the setup stronger.
x2 on the welding a nut onto the studs. I have had a lot of luck with that method.
I have also had luck with an engraving tool. Sharp, hardened tip that vibrates as you're turning. Works well depending on why the bolt snapped off. It doesn't work well on swaged threads or seized bolts for instance. For your application it might work well.
0 luck with easy outs or LH drill bits on anything not made of brass. They work well for air line fittings
Have fun? lol, this is gonna suck! :)
Thanks for the advice everyone. Good ideas to relocate. I will check and see how bad it is once I get the mud off of it tomorrow...
New Years Eve is not the right time to wrench...there is partying to be done!
Weld a nut on X3,
let it cool off, and back it out.........nothing eats rust like red hot:mad:
Weld a nut on X3,
What's rust? Not a spec on my rig. Just broken all to heck. I will be getting this done one way or the other by Friday so I can be good to go for the following weekend at Tellico :)
I feel kinda stupid asking, but can someone post a pic of what studs we are talking about? I'm pretty familiar with the rear axle assembly....at least i thought i was.
The drive plate (outside of the axle shaft) on the hub on the rear axle...in the middle. I sheered all the studs and nuts off of there and the axle popped out of the housing.
Go out and look at the middle of the rear wheel. You will see a bunch of 12 or 14mm bolts. They are the things that broke. If they do break, your axle will pop out too :)
Dan, I would love to talk about your truck over a beer. Mine is a work in progress (building it up as money/time/wife allows), but yours seems to be rock/mud ready and could give me some ideas.
I'd also like to see this repair done in person...because it will happen to me.
