OME install question...
TN
I got my OME stock replacement springs in yesterday...
I have read slee's instructions on thier site, and the spring removal/install instructions in the Haynes manual...
Doesn't seem TOO hard IMO..but, I do not have a floor jack, jack stands, etc while I am here at school...
So, I call around, and the cheapest estimate I can get in Oxford,MS is freakin 222.00 for LABOR only!!
Am I crazy, or is this just crazy expensive?!
Last weekend, I did put the truck on my back porch and replaced the valve cover gasket, cleaned the throttle body(as a side note; PO had a K&N air filter, since 1997 according to oil change records in glove box, and the inside of my throttle body and intake manifold were COATED in a greasy goo at least a few mm's thick...) I spent hours and hours cleaning the inside of the throttle body and intake manifold with a baby bottle brush...I also did new spark plugs, wires, spark plug gaskets, etc...and put an OEM air filter in. I dont' think the K&N did anything beneficial FWIW..so that is about the extent of my wrenching abilities.
So, to anyone who has self installed OME springs...could I solo this if I went and purchased two jack stands and a floor jack??? It is also freeeeeeezing cold here, which sucks when you don't have a shop..
Or, can someone recommend a shop near north MS, east TN or so that can help me for a reasonable sum...
Thanks, guys..
adamT
I did mine solo 2X. I used 2 HD jack stands, one large and one small floor jacks. Safety practice is the key here. I usually have somebody close by just in case and try to work in a level hard surface. I'm slow and getting slower and It took me a total of six hours the first time and almost 9 hours the second time around using hand tools.Purchasing air tools is in my future plan. :D The work includes installing 4 springs, 4 shocks, drop brackets and blocks for sway bars and a steering damper.
If you have jackstands and a floor jack, you can do it now.
You could do it with just a floor jack and your stock bottle jack, but it would be safer with jack stands.
Jack each end up individually as you do each spring. Take the wheel off, disconnect the shock, put the bottle jack between the axle and a frame or body point, and expand the bottle jack until there's enough room to swap springs. It's a one :banana: job, just takes lots of cranking.
I say jump on that $222 charge! A good floor jack and a minimum 2 stands will cost you half that, and if you have never seen/done this kind of work before I would ask if you could watch them perform the switch. Don't trifle with a 3 ton rig and try and jerry-rig a swap. That price would equate to less than $50 an hour I would think and sounds reasonable to have someone else loosen your shocks at one mount, disconnect your swaybar and perform the spring removal/install safely.
I had a friend nearly crushed by a FJ40 years ago doing a haphazard spring swap. I err on the side of caution and had 4 jack stands, 2 floor jacks and wheel chocks when I swapped my springs.
When I put the stock height kit on my wifes 80, I put it on without pulling the tire :p:eek: It takes some fenagling...but literally was 1.5 hours without air tools.
Just pull the shocks, jack it up as far as the opposite wheel will go (safely and use jackstands :) ) and you can get those springs in and out fairly easily.
If you don't have the tools, either find someone close who has them or pay someone to do it. Don't get squished!
EDIT>>>> on the front...it works best to drop the whole axle rather then one side. Easier to get the springs in/out...
so there are eaiser ways...I just liked the fact that if it falls it's going to land on a tire...not me :)
I hear that. I took each removed wheel and stuffed it under the frame on whatever corner I was working on, for the same reason. I'd rather dent a rim/pop a tire then lose a hand or a head.
That is a reasonable charge for a spring/shock install using your parts. Remember, they are non making any $ on your parts. Either find a local cruiser with the right tool who wants to help out, buy the right tools or use the shop.
IMHO, doing this without jackstands is a fools game. That is not to say the "tire on" method is risky. I have never tried that method FWIW.
Take BillRiley's offer, just bring the beer and limit it until the project is well under way -- don't need a novice and a drunk under a truck :grinpimp:.
That way you will kill two birds, you get your lift and you meet another cruiser owner.
Glen
yeah, i have to move to jackson,MS in May and plan on joining the cottonland cruisers there. so as to meet more owners and prob meet someone with the know-how, etc.
but, you know, waiting freakin' sucks when you lookin at your new springs every day. hahah...
I am more than willing to go to memphis fwiw...:) it is barely an hour away
I also just got my OME kit (2.5" medium) and went looking for install estimates. The first was from Expedition Autoworks at ~$1,200 bucks! So, I said to the guy, "hey guy, that's too :censor: much". :flipoff2: He was rude and estimated it to be a 12 hour job at $98 per hour for labor. Twelve hours, whatever.
I called Burnsville Offroad next and the dude was cool and said $550. :cheers: So the install is going in on Monday! :clap:
So be sure to check around. But to Red Crayon...that sounds like a hell of a deal.
Question...
I'm debating on new tire size. Should I go with the 285/75r/16 or the 315/75r/16? I don't want big gaps in the wheel wells, but I also don't want any tire rubbing. Do the 315 rub? Going with the BFGoodrich MT.
222.00 seems high for a spring swap. does that include an alignment?
I paid 200.00 including, spring replacement, shock replacement, CC bushings install, and an alignment. 850/860. I took it to the local Toy shop because I was leary about the CC bushing installation, and knew it should be aligned anyway after the install.
For a spring only job, I'd DIY if you feel you have the equip. to do it safely.
yeah, ome stock height springs only...have fairly new shocks..and i don't think it will need an alignment after spring only swap..
Weston,
Read up on here, but from what I remeber most can easily run the 315's with a 2.5" lift. FWIW there are even a couple that are running them with no lift.
Glen
I just added spacers and shocks to my OME lift. Did it alone, in my driveway, in about 2 hours.
I left the wheels on, disconnected the sway bar from the frame, disconnected the diff breather, undid the shock nuts, then just used a hilift to lift the body upward and let gravity hold the axle down. did one corner first, then the other (didn't do the back at all).
I can't see where jackstands under the axle instead of the tires on the ground actually offers any better support/protection: the tires are more stable. Not having tires there might give you a little more room to work, however.
Once or twice it ocurred to me that if the hilift were to give way then the truck could have smashed my hands, which obviously, would suck. It would add a lot of safety to have some sort of support between frame and axle while working there.
Like any job, move slowly, think about "what if" and minimize the chances of killing/maiming yourself, but swapping OME springs in for stock springs just isn't that difficult.... I would much rather spend some $ on getting better tools than on having someone else do this particular job.
Another thought: if you can find anyone who isn't freaked out about liability, and will let you use their lift (local gas stations?) then you can do the whole job in about an hour. Just disconnect the breathers and the brake line brackets (to give them room to move), disconnect the shock mounts (the top is easier, IMO), disconnect the sway bar where it mounts to the frame
then lift the frame, and the springs will come right off. swap in new spring, lower everything down and reconnect.
good luck
