What is the difference between the OME 4+ lift kits and the 3", 4", 5" competition lifts? I see the competition lifts use different springs? Thanks
So what do you guys suggest for lift? I have always heard that OME improves the ride.![]()
The OME comp springs gain rate via coil diameter and are going to be harsh if you ride them unloaded. Many complain of regular OME Heavy being harsh without several hundred lbs of load in the rear, although in the 4x4 world I personally think that's a bit overdone in a relative sense.
Ok before I start a thread where is some "Castor for dummies" info, and what per inch per lift spring is required.
like this,
OME low lift, not much anything
OME 2 1/2, castor bushings, shocks
Slee 4"....???
Slee...???
OME.....???
OME comp
and on and on
I would love some comp springs on my 3fe but right off the bat I smell a cut-n-turn..
it all depends on the weight you're carrying and the end resulting height change. Someone recently installed OME low springs and found he needed the OME bushings to correct for caster and bring it back to where he was pre lift.
So to answer your question, there is no "caster for dummies" answer. It needs to be figured out for your specific truck as there is too many variables to consider.
OK, I know there are lots of choices out there, so maybe I am looking for advise on setup based on my usage. My ride is 1994 bone stock 146K and locked. What I want to use it for:
1. Daily driver - no added weight
2. 6 or so trips to Moab a year for camping (loaded) and some wheeling like on Fins and Things.
3. Many other camping/off-road adventures in Colorado sometimes bringing my dirt bike on a tray off of the hitch.
What I am thinking:
1. yank the RB's...yuck
2. OLD MAN EMU 3-INCH MEDIUM-HEAVY PREMIUM KIT 8/92-97 80 SERIES **is the premium kit worth it???**
3. 305/70/16's
4. sliders
5. Later on build some front and rear bumpers/tire carrier.
Am I way off base herer? thx
do you guys use an angle finder?
