OME Castor Correction Bushing - Bolt Question
Planet Earth - Milky Way Galaxy
Getting ready to install the OME castor correction bushings in my 95 cruiser. The FSM indicates (if I'm reading it correctly) the bolts are NOT reusable. I have read many threads but have not read anything about replacing these bolts.
Are you guys putting new bolts in there when you install the new bushings?
Thanks
Imo if im replacing a part that wont need replacing for a good while, i change out the hardware when i put my new part in. For me its for sense of security. Then all the hardware thats used gets cleaned and goes in a standby/emergency bin.
I used the old bolts. 15k miles and some significant time in the dirt have not shown any issues.
I also used the old bolts (re installed with loctite), only because my toyota dealer didn't have new ones in stock & I wanted to get the arms installed on a Sunday .
Over 50k with no issues since .
I reused my old bots as well...
I reused old bolts. Remove them properly (ie. twist bolt and not the nut or vice versa, I can't remember) and they're totally re-useable.
