Old 3-speeds?
Everett WA
Hi all, I'm fixing up a '68 FJ40, mostly original except for a Man-A-Fre Rochester carb conversion that's pretty vintage itself.
1. I have the 3 speed column shift, want to go to floor shift. I have 2 spare 3-speeds with floor shifters, was thinking of cutting the floor and installing the floor shifter. Am I wasting my time here with the old 3-speeds- I mean, should I go for the later 4-speed box?
2. If I do go with a 4-speed floor shift, do I need to change to a later transfer case?
3. What do I do with the old 3-speeds? Anybody using these, or are they junk? Are any parts useable on 4-speeds- gears? shafts?
Thanx
Stick with the 3 speed. (I'd say stick with the 3 on the tree, but 3 on the floor is the next best thing).
IIRC the 4spd will need a different t-case.
That and welcome to Mud :flipoff2:
The three speed transmission is the same -- it's just the top that different. Keep your old tranny if it shifts OK (none of the three speeds shift that well acutally) or use one of your "newer" ones. Also, how about saving every last piece of the column shift linkage, including the reverse switch on the steering shaft -- I'm trying to tighten up my column shifter a bit. I usually try to talk folks into keeping their column shift but it sounds like you've decided ...
A common thing to do is use the older 3 speed (J30) transfer case and match it to a newer 4 speed (on the floor) transmission.
You are in Everett? Doing anything Tuesday night: wanna meet some local Seattle area cruiser nuts???
Check out www.seattlecruiserheads.com
Cheers,
Max
Actually I might stay with the column shift, since the truck is original style. Haven't decided. Just looking at options.
Max, I dig the Cruiserheads site! How is the 3 speed transfer case adapted to a 4-speed box? What is different between the 3-speed box and transfer VS the 4-speed box and transfer? So many questions from a newbie, I know.
Thanx
(another ) Max :cheers:
LittleFJ said:
Actually I might stay with the column shift, since the truck is original style. Haven't decided. Just looking at options. I dig the Cruiserheads site!
Max, how is the 3 speed transfer case adapted to a 4-speed box? What is different between the 3-speed box and transfer VS the 4-speed box and transfer?
Thanx
As you can tell from the various responses there are many ways to skin this particular cat. If you are doing a cool resto project then I would look to keep your project stock and keep the same style of gearing that came with the year that your 40 was built.
If you are more looking for a updated street/trail friendly truck then there are many options. Some guys don't like the 3 speed on the "tree" and opt for a 4 speed on the "floor." Having that extra gear gives you more shifting options and some prefer shifting with the stick on the floor. The thing to remember is that Toyota had a combined gear ratio throughout the run of these magnificent machines. I refer to the combined ratio of the transmission and transfer case. The product of these two numbers multiplied by the gear ratio in the axles produces a number that is called the crawl ratio. Through the years Toyota changed the transmission and the transfer case but kept the product of these two factors pretty much the same. The older style transfer cases have a deeper ratio than the newer 4 speed cases. Toyota changed the cases when they offered the lower 1st gear that came with the 4 speed transmission. A lot of folks have chosen to mate the older transfer case(called the J30 case) with the newer 4 speed transmission. This combo is a quick way of getting good street manners in 2 wheel drive (2-Hi) and slightly lower gearing for the trail in 4-Low. The last couple of years of the J30 case produced stronger cases than was common in the cases produced in the 60's. Doing this will not create a rock crawling competition machine. Far from it. But it would offer slight improvement for the street and moderate trail use.
In the end it is hard to create a great street friendly FJ40 and a low crawling trail rig with the same gearing. You have to lean one way or the other. There are options to creating this Holy Grail but it will cost you dollars.
If you are somewhat new to all of this I would caution you against doing anything for a while. Drive your rig as it is under different conditions. Spend more time learning about what you already have rather than dreaming what you can build. Even if your goals are to wheel hard on the trails here in Washington do not get blown away by some great website that features a radical rig buildup in open dessert conditions in California or Arizona. Build the rig for LOCAL conditions. Trails in Washington ARE different to many other parts of the country: the challenges are not the same. The more interesting trails in Washington offer tight tree lined off camber trails. There is not as much big rock wheeling here. Still, our local trails are a real challenge as you need to pay attention to sheet metal ruining obstacles at the window or roof level. I know guys who have wheeled in difficult famous places like the Rubicon and have come out unscathed but have bashed the snot out of their rigs on seemingly easy trails in Washington.
So, for now I would suggest you act like Mr. Spock from Star Trek and suck all the information you can from the minds of others before you go tearing into your rig.
Cheers,
Max
bull said:
3 on the tree vote here...classic and acts as a theft deterrent
I just had a nightmare last night that someone stole my 3/tree FJ45. :mad:
That said, I never take the key out of the cylinder lock where ever I go and feel great about it in real life.
I just finished getting my cruiser up and running. I have a 1970 FJ40, and I'm loving the three on the tree! The tranny is a bit rough, but I think it's more retro, and unless I had a newer cruiser wouldn't want it any other way.
Keep the tree!
